I’m trying to install scrcpy
on my machine. I follow this Instruction but I’m getting problem on libavformat
Here’s the log
Build started at 2022-02-10T07:47:40.664846
Main binary: /usr/bin/python3
Build Options: -Db_lto=true -Dprebuilt_server=scrcpy-server -Dprefix=/usr/local -Dbuildtype=release -Dstrip=True
Python system: Linux
The Meson build system
Version: 0.61.1
Source dir: /home/nextgenop/gittt/scrcpy
Build dir: /home/nextgenop/gittt/scrcpy/build-auto
Build type: native build
Project name: scrcpy
Project version: 1.22
Sanity testing C compiler: gcc
Is cross compiler: False.
Sanity check compiler command line: gcc sanitycheckc.c -o sanitycheckc.exe -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -Wformat -Wformat-security -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -fno-semantic-interposition -ffat-lto-objects -fno-trapping-math -mtune=skylake -D_FILE_OFFSET_BITS=64
Sanity check compile stdout:
Sanity check compile stderr:
Running test binary command: /home/nextgenop/gittt/scrcpy/build-auto/meson-private/sanitycheckc.exe
C compiler for the host machine: gcc (gcc 11.2.1 “gcc (Clear Linux OS for Intel Architecture) 11.2.1 20220124 releases/gcc-11.2.0-705-gce3954262a”)
C linker for the host machine: gcc ld.bfd 2.37
C compiler for the build machine: gcc (gcc 11.2.1 “gcc (Clear Linux OS for Intel Architecture) 11.2.1 20220124 releases/gcc-11.2.0-705-gce3954262a”)
C linker for the build machine: gcc ld.bfd 2.37
Build machine cpu family: x86_64
Build machine cpu: x86_64
Host machine cpu family: x86_64
Host machine cpu: x86_64
Target machine cpu family: x86_64
Target machine cpu: x86_64
Pkg-config binary for 1 is not cached.
Pkg-config binary missing from cross or native file, or env var undefined.
Trying a default Pkg-config fallback at pkg-config
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Determining dependency ‘libavformat’ with pkg-config executable ‘/usr/bin/pkg-config’
env[PKG_CONFIG_PATH]:
Called/usr/bin/pkg-config --modversion libavformat
→ 1CMake binary for 1 is not cached
CMake binary missing from cross or native file, or env var undefined.
Trying a default CMake fallback at cmake
Found CMake: /usr/bin/cmake (3.22.1)
Extracting basic cmake information
CMake Toolchain: Calling CMake once to generate the compiler state
Calling CMake ([‘/usr/bin/cmake’]) in /home/nextgenop/gittt/scrcpy/build-auto/meson-private/CMake_compiler_info with:
- “–trace-expand”
- “–trace-format=json-v1”
- “–no-warn-unused-cli”
- “–trace-redirect=cmake_trace.txt”
- “-G”
- “Ninja”
- “-DCMAKE_TOOLCHAIN_FILE=/home/nextgenop/gittt/scrcpy/build-auto/meson-private/CMake_compiler_info/CMakeMesonTempToolchainFile.cmake”
Try CMake generator: auto
Calling CMake ([‘/usr/bin/cmake’]) in /home/nextgenop/gittt/scrcpy/build-auto/meson-private/cmake_libavformat with:- “–trace-expand”
- “-DCMAKE_TOOLCHAIN_FILE=/home/nextgenop/gittt/scrcpy/build-auto/meson-private/cmake_libavformat/CMakeMesonToolchainFile.cmake”
– Module search paths: [‘/’, ‘/opt’, ‘/usr’, ‘/usr/local’]
– CMake root: /usr/share/cmake-3.22
– CMake architectures:
– CMake lib search paths: [‘lib’, ‘lib32’, ‘lib64’, ‘libx32’, ‘share’]
Preliminary CMake check failed. Aborting.
Run-time dependency libavformat found: NO (tried pkgconfig and cmake)app/meson.build:94:4: ERROR: Dependency “libavformat” not found, tried pkgconfig and cmake
This log is obtained after adding env LD_LIBRARY_PATH=/usr/local/lib
in front of the meson
command.
And this is the result of ls /usr/local/lib
$ ls /usr/local/lib
libaom.so libfdk-aac.so libvidstab.so
libaom.so.3 libfdk-aac.so.2 libvidstab.so.1.2
libaom.so.3.0.0 libfdk-aac.so.2.0.2 libvmaf.so
libavcodec.so libhdr10plus.so libvmaf.so.1
libavcodec.so.58 libmp3lame.so libvmaf.so.1.1.1
libavcodec.so.58.134.100 libmp3lame.so.0 libx26410b.so
libavdevice.so libmp3lame.so.0.0.0 libx26410b.so.164
libavdevice.so.58 libopus.so libx264.so
libavdevice.so.58.13.100 libopus.so.0 libx264.so.164
libavfilter.so libopus.so.0.8.0 libx265_main10.so
libavfilter.so.7 libpostproc.so libx265_main10.so.199
libavfilter.so.7.110.100 libpostproc.so.55 libx265_main12.so
libavformat.so libpostproc.so.55.9.100 libx265_main12.so.199
libavformat.so.58 libSvtAv1Enc.so libx265.so
libavformat.so.58.76.100 libSvtAv1Enc.so.0 libx265.so.199
libavutil.so libSvtAv1Enc.so.0.8.7 libxvidcore.so
libavutil.so.56 libswresample.so libxvidcore.so.4
libavutil.so.56.70.100 libswresample.so.3 libxvidcore.so.4.3
libdav1d.so libswresample.so.3.9.100 pkgconfig
libdav1d.so.5 libswscale.so zram.conf.d
libdav1d.so.5.0.1 libswscale.so.5
libfdk-aac.la libswscale.so.5.9.100
how to fix it?
