I have been trying to get libdecor to compile on Clear Linux*, as Blender 3.4.1 requires it to be able to work under Wayland, otherwise it falls back to X11.
I used the following in the Terminal, as per their instructions:
cd /tmp
git clone https://gitlab.freedesktop.org/libdecor/libdecor
cd libdecor
meson build --buildtype release
However I get the following feedback with an error:
**The Meson build system**
Version: 1.0.0
Source dir: /tmp/libdecor
Build dir: /tmp/libdecor/build
Build type: native build
Project name: libdecor
Project version: 0.1.0
C compiler for the host machine: gcc (gcc 12.2.1 "gcc (Clear Linux OS for Intel Architecture) 12.2.1 20230105 releases/gcc-12.2.0-333-gebb1f6d14c")
C linker for the host machine: gcc ld.bfd 2.39.0
Host machine cpu family: x86_64
Host machine cpu: x86_64
Compiler for C supports arguments -Wno-unused-parameter: YES
Compiler for C supports arguments -Wno-missing-field-initializers: YES
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Run-time dependency wayland-client found: YES 1.21.0
Run-time dependency wayland-protocols found: YES 1.31
Library dl found: YES
Run-time dependency dbus-1 found: YES 1.14.4
Checking for function "asprintf" : YES
Checking for function "mkostemp" : NO
Checking for function "posix_fallocate" : YES
Checking for function "memfd_create" : YES
Configuring config.h using configuration
Program wayland-scanner found: YES (/usr/bin/wayland-scanner)
Run-time dependency gtk+-3.0 found: YES 3.24.34
Run-time dependency cairo found: YES 1.16.0
Library m found: YES
Run-time dependency pangocairo found: YES 1.50.12
Run-time dependency wayland-cursor found: YES 1.21.0
Dependency wayland-cursor found: YES 1.21.0 (cached)
C++ compiler for the host machine: g++ (gcc 12.2.1 "g++ (Clear Linux OS for Intel Architecture) 12.2.1 20230105 releases/gcc-12.2.0-333-gebb1f6d14c")
C++ linker for the host machine: g++ ld.bfd 2.39.0
Run-time dependency egl found: YES 23.0.0-devel
Found CMake: /usr/bin/cmake (3.25.1)
Run-time dependency opengl found: NO (tried pkgconfig and cmake)
demo/meson.build:8:0: ERROR: Dependency "opengl" not found, tried pkgconfig and cmake
Which bundle / package (dependency “opengl”) should I get to fix this…? Many thanks for any usable reply!
