Libavformat-dev, libavutil-dev, and libavcodec-dev
An application I am trying to install has libavformat-dev, libavutil-dev, and libavcodec-dev as dependencies. Is there a CL bundle that contains these?
repo:clearlinux/clr-bundles ffmpeg
Thanks. Looks like my app is still complaining though (after installing the bundles you suggested):
[h264_qsv @ 0x557498000c70] Error initializing an internal MFX session: unsupported (-3)
[h264_qsv @ 0x557498000c70] Error initializing an MFX session
[h264_qsv @ 0x557498000c70] Error initializing the MFX video decoder: invalid handle (-6)
What do you make of this?
Also, what’s the difference between this and CL’s (not-)ffmpeg bundles?
x264 lib isn’t installed.
Thank you. And how would I go about installing that please? (Feel free to suggest something from here, if applicable.)
You can:
  • extract the x264 lib & headers from Clear Fraction release RPM in packages-xxxxx.tar
  • compile it yourself using the spec.
Thank you. Is that an “and” or an “or” between the two bullets?
“Or”, of course.
Thank you. Now that my question made you realize the real “depth” of my knowledge of such matters :blush: , it goes w/o saying that I will need a bit of hand-holding in this quest (and feel free to decline the “honor,” no hard feelings).
My guess is that x264-libs-0.164-20230128.x86_64.rpm is the “lib” file, though which one is the “headers”? And once I have the two, I guess that I should do a make & make install, right?
Correct.
The *-dev package.
No, that’s for compilation, these packages are already compiled.
I don’t know if your app will work with this library & ffmpeg, so you probably need to recompile your app.
Silly me: Yes, .rpm are already compiled. Even I know that! :blush:
How to build software using Clear Fraction libraries like x264, x265 or CUDA
Looks like I am missing a link in my quest to run the following command:
gcc AURGAViewer.a libmatoya.a libavcodec.a libavutil.a libavformat.a libswscale.a -fPIC -ldl -lpthread -ludev -lm -lstdc++ -o AURGAViewer.
I got gcc, ffmpeg, and x264 installed, and I need to obtain these four files: libavcodec.a, libavutil.a, libavformat.a, and libswscale.a. How do I do that?
Hope you got it working, but for the records:
  • .a is a static library
  • you can search any file with find command
Thanks, I had to compile ffmpeg from scratch, as I don’t know how to generate the .a files from the CF bundle.
