I try to configure AWS IoT greengrass on my myriad devices but it cannot found it even though I already attach the devices path directory (/dev/bus/usb/003). Can anyone help me with this? Thank you
Hi Nadiah, Can I get more info? I’ve also run into issues with Greengrass on an edge device. Do you have the following bundles installed?
- aws-greengrass-iot
- cloud-api
and can you let me know the command you used that fails? I can’t tell from the screen shot.
Thank you for your quick response.
I’m following this link to configure Lambda.
https://docs.01.org/clearlinux/latest/guides/stacks/greengrass.html
But in this example, there is no mention about target device, MYRIAD. I already add both two bundles, aws-greengrass-iot and cloud-api. Additionally, if my target device is CPU, it works fine for me.
Here I attach the lamba resource configuration. I cannot attach the lambda function log file here. If you need it let me know I will send an email
Thanks for the detail – the tutorial you’re following is a bit outdated and didn’t include Myriad support. Can you take a look at this github project: https://github.com/intel/Edge-Analytics-FaaS/tree/master/AWS%20Greengrass/Clear_Linux which may help?
Unfortunately in the accompanying Ubuntu instructions for that repo there’s a statement that “Movidius hasn’t been validated with Greengrass yet. This section will be updated in future releases.”
