Hello community,
i have a problem connecting my Logitech MX2 - mouse via Bluetooth.
I tried to reboot, shut down but i can’t activate it in the GNOME-control-center.
When I ask for status of Bluetooth via systemctl - command i get the following messages:
luetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2022-05-28 13:46:13 CEST; 7min ago
Docs: man:bluetoothd(8)
Process: 1739 ExecStart=/usr/libexec/bluetooth/bluetoothd (code=exited, status=226/NAMESPACE)
Main PID: 1739 (code=exited, status=226/NAMESPACE)
Mai 28 13:46:13 clr-precision systemd[1]: Starting Bluetooth service…
Mai 28 13:46:13 clr-precision systemd[1739]: bluetooth.service: Failed to set up mount namespacing: /run/systemd/unit-root/var/lib/bluetooth: No such file or d>
Mai 28 13:46:13 clr-precision systemd[1739]: bluetooth.service: Failed at step NAMESPACE spawning /usr/libexec/bluetooth/bluetoothd: No such file or directory
Mai 28 13:46:13 clr-precision systemd[1]: bluetooth.service: Main process exited, code=exited, status=226/NAMESPACE
Mai 28 13:46:13 clr-precision systemd[1]: bluetooth.service: Failed with result ‘exit-code’.
Mai 28 13:46:13 clr-precision systemd[1]: Failed to start Bluetooth service.
Has anyone an idea which could be the problem?
Thank you.
