The packages that I required are
1.Touchegg
2.Plank
3.Vnstat
And also can anyone help me with how to install rpm packages with clear instructions.
1.Touchegg
2.Plank
3.Vnstat
Click search icon in upper right corner of forum. Type “dnf” or “rpm”. Profit.
Touchegg
I think the process you tagged is quite unfamiliar to this package.
When I went through manually and when entering the make it says no target is selected and same with make install.
The above process helped me with Brave I can’t import this
it says clearly that you don’t have a package
But I installed the whole dev package for that small package but still, it shows that even after a reboot.
just read it
you don’t have ‘pugixml’
It doesn’t have pugixml.pc
so cmake cannot find it.
Just build it from source too.
