I created a virtual environment and installed intel-tensorflow package but while importing tensorflow I get following error:
>>> import tensorflow Traceback (most recent call last): File "<stdin>", line 1, in <module> ModuleNotFoundError: No module named 'tensorflow'
Steps that I tried are below:
user@clearos~/.virtualenvs $ python -m venv my_env user@clearos~/.virtualenvs $ source my_env/bin/activate (my_env) user@clearos~/.virtualenvs $ pip --no-cache-dir install intel-tensorflow Collecting intel-tensorflow Downloadinghttps://files.pythonhosted.org/packages/6b/62/b63a6b446ffe15a63a63c2d1f2ae7d19666e7276df07835a3898737c2ff2/intel_tensorflow-0.0.1-py2.py3-none-any.whl Requirement already satisfied: pip>=10.0.1 in ./my_env/lib/python3.8/site-packages (from intel-tensorflow) (19.2.3) Installing collected packages: intel-tensorflow Successfully installed intel-tensorflow-0.0.1 WARNING: You are using pip version 19.2.3, however version 20.0.2 is available. You should consider upgrading via the 'pip install --upgrade pip' command. (my_env) user@clearos~/.virtualenvs $ python Python 3.8.1 (default, Mar 30 2020, 14:50:54) [GCC 9.3.1 20200327 releases/gcc-9.3.0-58-g070a0b6392] on linux Type "help", "copyright", "credits" or "license" for more information. >>> import tensorflow Traceback (most recent call last): File "<stdin>", line 1, in <module> ModuleNotFoundError: No module named 'tensorflow'
(my_env) user@clearos~/.virtualenvs $ pip install intel-tensorflow
Using cached https://files.pythonhosted.org/packages/6b/62/b63a6b446ffe15a63a63c2d1f2ae7d19666e7276df07835a3898737c2ff2/intel_tensorflow-0.0.1-py2.py3-none-any.whl
Requirement already satisfied: pip>=10.0.1 in ./my_env/lib/python3.8/site-packages (from intel-tensorflow) (19.0)
You are using pip version 19.0, however version 20.0.2 is available.
>>> import tensorflow
I tried using --no-cache-dir option with pip install but got another error.
Downloading https://files.pythonhosted.org/packages/6b/62/b63a6b446ffe15a63a63c2d1f2ae7d19666e7276df07835a3898737c2ff2/intel_tensorflow-0.0.1-py2.py3-none-any.whl
Exception:
File "/home/user/.virtualenvs/my_env/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 176, in main
status = self.run(options, args)
File "/home/user/.virtualenvs/my_env/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 344, in run
build_failures = wb.build(
File "/home/user/.virtualenvs/my_env/lib/python3.8/site-packages/pip/_internal/wheel.py", line 848, in build
assert building_is_possible
AssertionError
While installing normal tensorflow v1 , I get following error
(my_env) user@clearos~/.virtualenvs $ pip install tensorflow-cpu==1.15
Collecting tensorflow-cpu==1.15
Could not find a version that satisfies the requirement tensorflow-cpu==1.15 (from versions: 2.2.0rc1, 2.2.0rc2)
No matching distribution found for tensorflow-cpu==1.15
I tried with both, tensorflow and tensorflow-cpu. No success in either. Same error message.
(my_env) user@clearos~/.virtualenvs $ pip install tensorflow==1.15
Collecting tensorflow==1.15
Could not find a version that satisfies the requirement tensorflow==1.15 (from versions: 2.2.0rc1, 2.2.0rc2)
No matching distribution found for tensorflow==1.15
