Got NME_UNSPEC error when activating VLAN connection with the same parent device, same vlan_id but different ipv4 configuration.
Please also take a look: 1774074 – Creating vxlan fails with NME_UNSPEC
This is the unspecified error. You need to report this to the upstream and get freeback from there.
Sorry, how do i report it to the upstream?
NetworkManager is hosted on Gitlab, you report at Issues · NetworkManager / NetworkManager · GitLab
Sometimes, it really is NetworkManager’s fault. If you think that’s the case, please file a bug at:
Attaching NetworkManager debug logs from the journal (or wherever your distribution directs syslog’s ‘daemon’ facility output, as /var/log/messages or /var/log/daemon.log) is often very helpful, and (if you can get) a working wpa_supplicant config file helps enormously.
