I’m using firewalld and tried bringing up docker at the same time. Docker does come up, but the networking does not work properly (dns resolving from inside container fails). I’ve pasted journal messages below. Has anyone been able to get docker working with firewalld?
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.3 (legacy): Couldn't load target `DOCKER':No such file or directory
Try `iptables -h' or 'iptables --help' for more information.
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER' failed: iptables v1.8.3 (legacy): Couldn't load target `DOCKER':No such file or directory
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.3 (legacy): Couldn't load target `DOCKER':No such file or directory
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING' failed: iptables: Bad rule (does a matching rule exist in that chain?).
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -F DOCKER' failed: iptables: No chain/target/match by that name.
COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -X DOCKER' failed: iptables: No chain/target/match by that name.
