New:
- New UI feature shows language used in code-blocks
Revised docs :
New:
Revised docs :
What was revised in Install Clear Linux* OS from the live desktop especially in Advanced installation? Why should the partitions have to be named CLR_BOOT etc?
@mvincerra might have more details for you
The advanced configuration now uses gparted, which allows you to partition disk space before completing installation. Partition names like CLR_BOOT, CLR_SWAP, etc., are required in order for the Clear Linux installer to identify which partitions to use for the installation.
Also, support for offline installs is accounted for in the documentation
Why can’t boot be a part of root, rather than a separate partition?
I think this post from @bun.k.tan should be added to the Install Clear Linux from the live desktop.. After so many years of using Grub, i understood the idea of systemd-boot in Clear Linux correctly. Through it, I understood having few /boot/efi partitions too. ![]()
