I have in Gnome Wayland two monitors attached to a Intel NUC8i7BEH. One via HDMI. One by USB Type C alternate mode on Thunderbolt 3 port. HDMI is a monitor Acer ET322QK. USB alternate mode is a Faytech lapscreen 10-Point-Multi-Touch-Version.
Using dual monitor extended mode:
xrandr --query
Screen 0: minimum 320 x 200, current 5760 x 2160, maximum 8192 x 8192
XWAYLAND0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 700mm x 390mm
3840x2160 59.98*+
XWAYLAND1 connected 1920x1080+3840+0 (normal left inverted right x axis y axis) 470mm x 260mm
1920x1080 59.96*+
How can I use mirroring (cloning) with same set-up having HDMI 3840x2160 scaling 200 percent and
1920x1080 100percent?
