When I run clr-service-restart to see which service need to be restarted, I get a strange error:
$ sudo clr-service-restart -a -n
readlink: No such file or directory
Can you check the output of sudo ls -l /usr/share/clr-service-restart
and sudo ls -l /etc/clr-service-restart
An strace
might be useful as well: sudo strace clr-service-restart -a -n
$ sudo ls -l /usr/share/clr-service-restart
total 0
lrwxrwxrwx 1 root root 38 Feb 5 20:51 mcelog.service -> /usr/lib/systemd/system/mcelog.service
lrwxrwxrwx 1 root root 44 May 9 02:45 pacdiscovery.service -> /usr/lib/systemd/system/pacdiscovery.service
lrwxrwxrwx 1 root root 41 May 9 02:45 pacrunner.service -> /usr/lib/systemd/system/pacrunner.service
lrwxrwxrwx 1 root root 36 Dec 19 23:36 rngd.service -> /usr/lib/systemd/system/rngd.service
lrwxrwxrwx 1 root root 48 Feb 1 20:26 systemd-journald.service -> /usr/lib/systemd/system/systemd-journald.service
lrwxrwxrwx 1 root root 48 Feb 1 20:26 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
lrwxrwxrwx 1 root root 49 Feb 1 20:26 systemd-timesyncd.service -> /usr/lib/systemd/system/systemd-timesyncd.service
lrwxrwxrwx 1 root root 45 Feb 1 20:26 systemd-udevd.service -> /usr/lib/systemd/system/systemd-udevd.service
lrwxrwxrwx 1 root root 38 Apr 19 22:50 tallow.service -> /usr/lib/systemd/system/tallow.service
$ sudo ls -l /etc/clr-service-restart
total 0
lrwxrwxrwx 1 root root 36 May 22 19:33 dbus.service -> /usr/lib/systemd/system/dbus.service
lrwxrwxrwx 1 root root 46 May 22 19:33 systemd-logind.service -> /usr/lib/systemd/system/systemd-logind.service
Sorry for the unformatted posts, I’m doing this from my phone so it’s a bit awkward.
This seems to be the offending call to readlink:
readlink("/proc/2966/exe", 0x7ffcc3911b40, 4096) = -1 ENOENT (No such file or directory)
dup(2</dev/pts/1<char 136:1>>) = 5</dev/pts/1<char 136:1>>
fcntl(5</dev/pts/1<char 136:1>>, F_GETFL) = 0x2 (flags O_RDWR)
fstat(5</dev/pts/1<char 136:1>>, {st_mode=S_IFCHR|0620, st_rdev=makedev(0x88, 0x1), ...}) = 0
write(5</dev/pts/1<char 136:1>>, "readlink: No such file or direct"..., 36readlink: No such file or directory
Pid 2966 is a process named [vhost-2964], it seems to be a docker-related process.
Bare metal, on a Atom C2758 based Supermicro A1SRi-2758F to be exact.
Seems to be a bug in clr-service-restart
. I’ll need to figure out how to reproduce this as it’s my own code.
It’s rather strange. /proc/2699/exe exists, but readlink fails on it. ls -l /proc/2699 lists it as a symolic link but shows no -> arrow. I’ll try to do more investigation later.
On further investigation, this process is actually a kernel thread, which would explain why exe symlink didn’t resolve to an executable.
I’ve looked at what clr-service-restart is doing and noticed that the kernel thread (pid 2966) is listed in /sys/fs/cgroup/systemd/system.slice/docker.service/tasks on my system.
I think you need to identify kernel threads and skip over them.
Thanks, that was helpful. Yes, kernel threads behave special here, so there isn’t much else to do but to look at errno
and compare with ENOENT
