Sadly, am not sure how long but there was an incorrect setting for Firefox preventing it from decoding using hardware acceleration using NVIDIA graphics. The following was false in the documentation for some time. It must remain enabled (default) or decoding via hardware acceleration will not work.
media.rdd-process.enabled true
I now verify libraries used. In the case of Firefox, I look for vdpau_drv_video.so
or nvidia_drv_video.so
while playing a video. Depending on using the vdpau-va-driver-v9 or the nvdec-enabled-vaapi driver, respectively.
$ lsof | egrep -e 'dri/vdpau_drv_video' -e 'dri/nvidia_drv_video'
Correct.
I appreciate that you reach out @pixelgeek. There is another sadness of it all and itâs the swupd
tool. It can break the NVIDIA driver installation. For that reason, I do not mention Clear Linux to my friends using NVIDIA graphics.
Otherwise if one doesnât update (likely not recommended), the desktop experience is awesome. Even more so due to utilizing the video engine on the GPU. I enable ForceCompositionPipeline which rids of any jitters.
$ cat /etc/X11/xorg.conf.d/nvidia-screen-opt.conf
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
There is happiness (what an amazing desktop experience) and sadness (dislike the swupd tool breaking the NVIDIA driver installation). I havenât had the time to investigate ignore files.
Hopeful; ++ for the day the swupd
tool is mindful of the NVIDIA driver installation.
Well, itâs a moment of celebration.
Nothing that I can talk about yet
I downloaded the developer Chrome and automatically came with ffmpeg support and can watch youtube and such.
I ran the installation BASH and got one error this:
`ERROR: cuvid requested, but not all dependencies are satisfied: ffnvcodec
