Hello,
when CL updates the kernel I need to reinstall the nvidia driver. It would be nice to get a notification in GNOME when that happens.
Thanks.
Hello,
Thanks.
Would the notification be before you reboot the system or after? When I ssh into my system I often see this message but only when clear linux auto updated.
It would be good to have that notification before reboot to activate a new kernel. The effect with the nvidia driver is that GNOME becomes slow once a new kernel is loaded, and it can be confused with CPU performance/fan settings on my notebook as I switch between performance and silent mode.
A little notification in the GNOME desktop would make things more clear and I would know I have to prepare for the driver reinstall.
You might add onto this feature request:
For the nvidia driver, DKMS should be rebuilding the driver for you automatically when there is a kernel update. A reinstallation should only be required if one of the conflicting files gets overwritten (from the mesa package) or there is a compatibility issue between the kernel version and nvidia driver (in which case you’d probably need to update the driver, not just reinstall it).
