I need use plagin in vs-code, but vs-code $PATH != system $PATH . I use Clear linux. If i use echo $PATH in terminal, i get:
/usr/lib/go:/usr/lib/go:/usr/lib/go:/usr/bin/haswell:/usr/local/bin:/usr/bin:/opt/3rd-party/bin
But i use VS-code, $PATH:
/app/bin:/usr/bin:/home/lostlang/.var/app/com.visualstudio.code/data/node_modules/bin
How can i make my VS-code $PATH be equal system $PATH? Or how append folder to vs-code $PATH ?
