android@clr~/broadcom-wl $ make clean
KBUILD_NOPEDANTIC=1 make -C /lib/modules/`uname -r`/build M=`pwd` clean
make[1]: Entering directory '/usr/lib/modules/5.2.14-833.native/build'
CFG80211 API is prefered for this kernel version
/home/android/broadcom-wl/Makefile:99: Neither CFG80211 nor Wireless Extension is enabled in kernel
CLEAN /home/android/broadcom-wl/.tmp_versions
CLEAN /home/android/broadcom-wl/Module.symvers
make[1]: Leaving directory '/usr/lib/modules/5.2.14-833.native/build'
Using CFG80211 API
CC [M] /home/android/broadcom-wl/src/shared/linux_osl.o
CC [M] /home/android/broadcom-wl/src/wl/sys/wl_linux.o
In file included from ./include/linux/bitmap.h:9,
from ./include/linux/cpumask.h:12,
from ./arch/x86/include/asm/cpumask.h:5,
from ./arch/x86/include/asm/msr.h:11,
from ./arch/x86/include/asm/processor.h:21,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
from ./include/linux/thread_info.h:38,
from ./arch/x86/include/asm/preempt.h:7,
from ./include/linux/preempt.h:78,
from ./include/linux/spinlock.h:51,
from ./include/linux/seqlock.h:36,
from ./include/linux/time.h:6,
from ./include/linux/stat.h:19,
from ./include/linux/module.h:10,
from /home/android/broadcom-wl/src/include/linuxver.h:40,
from /home/android/broadcom-wl/src/wl/sys/wl_linux.c:27:
In function ‘strncpy’,
inlined from ‘_wl_add_monitor_if’ at /home/android/broadcom-wl/src/wl/sys/wl_linux.c:2990:2:
./include/linux/string.h:260:9: warning: ‘__builtin_strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=]
260 | return __builtin_strncpy(p, q, size);
/home/android/broadcom-wl/src/wl/sys/wl_linux.c: In function ‘_wl_add_monitor_if’:
./include/linux/string.h:281:10: note: length computed here
281 | return __builtin_strlen(p);
CC [M] /home/android/broadcom-wl/src/wl/sys/wl_iw.o
CC [M] /home/android/broadcom-wl/src/wl/sys/wl_cfg80211_hybrid.o
LD [M] /home/android/broadcom-wl/wl.o
Building modules, stage 2.
Using CFG80211 API
MODPOST 1 modules
CC /home/android/broadcom-wl/wl.mod.o
LD [M] /home/android/broadcom-wl/wl.ko
android@clr~/broadcom-wl $ sudo make install
install -D -m 755 wl.ko /lib/modules/`uname -r`/kernel/drivers/net/wireless
android@clr~/broadcom-wl $ sudo cp wl.ko /lib/modules/5.2.13-832.native/kernel/drivers/net/wireless
android@clr~/broadcom-wl $ sudo modprobe wl
modprobe: FATAL: Module wl not found in directory /lib/modules/5.2.14-833.native
android@clr~/broadcom-wl $ sudo cp wl.ko /lib/modules/5.2.14-832.native/kernel/drivers/net/wireless
cp: cannot create regular file '/lib/modules/5.2.14-832.native/kernel/drivers/net/wireless': No such file or directory
android@clr~/broadcom-wl $ sudo cp wl.ko /lib/modules/5.2.14-833.native/kernel/drivers/net/wireless
android@clr~/broadcom-wl $ sudo dmesg
[ 0.192910] pci 0000:00:1c.5: Enabling MPC IRBNCE
[ 0.192912] pci 0000:00:1c.5: Intel PCH root port ACS workaround enabled
[ 0.193053] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.193078] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d17000-0xf7d173ff]
[ 0.640785] sd 0:0:0:0: [sda] Write Protect is off
[ 0.640787] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.640817] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.641260] scsi 4:0:0:0: CD-ROM HL-DT-ST DVD+-RW GU70N A103 PQ: 0 ANSI: 5
[ 0.656227] probe of 4:0:0:0 returned 0 after 5 usecs
[ 0.656333] scsi 4:0:0:0: Attached scsi generic sg1 type 5
[ 0.704235] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.720235] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 0.720258] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.746883] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8
[ 0.747468] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.833025] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.833027] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.833455] hub 1-1:1.0: USB hub found
[ 0.833654] hub 1-1:1.0: 6 ports detected
[ 0.835226] probe of 1-1:1.0 returned 1 after 1778 usecs
[ 0.835256] probe of 1-1 returned 1 after 2133 usecs
[ 0.848784] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.848786] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.849130] hub 2-1:1.0: USB hub found
[ 0.849372] hub 2-1:1.0: 6 ports detected
[ 6.237349] probe of 0000:00:1f.3 returned 1 after 1068 usecs
[ 6.237371] initcall i2c_i801_init+0x0/0x1000 [i2c_i801] returned 0 after 1079 usecs
[ 6.255094] calling acpi_thermal_init+0x0/0x1000 [thermal] @ 321
[ 6.265789] calling init_soundcore+0x0/0x1000 [soundcore] @ 317
[ 6.265803] initcall init_soundcore+0x0/0x1000 [soundcore] returned 0 after 9 usecs
[ 6.269486] calling mei_me_driver_init+0x0/0x1000 [mei_me] @ 318
[ 6.269532] initcall mei_me_driver_init+0x0/0x1000 [mei_me] returned 0 after 39 usecs
[ 6.272669] thermal LNXTHERM:00: registered as thermal_zone1
[ 6.272671] ACPI: Thermal Zone [THM] (60 C)
[ 6.272694] probe of LNXTHERM:00 returned 1 after 17462 usecs
[ 6.272708] initcall acpi_thermal_init+0x0/0x1000 [thermal] returned 0 after 3141 usecs
[ 6.275287] probe of 0000:00:16.0 returned 1 after 5775 usecs
[ 6.289292] calling alsa_sound_init+0x0/0x93 [snd] @ 317
[ 6.289307] initcall alsa_sound_init+0x0/0x93 [snd] returned 0 after 9 usecs
[ 6.294206] calling acpi_wmi_init+0x0/0x1000 [wmi] @ 329
[ 6.294330] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 6.294454] probe of PNP0C14:00 returned 1 after 205 usecs
[ 6.294473] initcall acpi_wmi_init+0x0/0x1000 [wmi] returned 0 after 256 usecs
[ 6.332347] calling alsa_timer_init+0x0/0x1000 [snd_timer] @ 317
[ 6.332405] initcall alsa_timer_init+0x0/0x1000 [snd_timer] returned 0 after 51 usecs
[ 6.345393] calling cdrom_init+0x0/0x1000 [cdrom] @ 329
[ 6.345404] initcall cdrom_init+0x0/0x1000 [cdrom] returned 0 after 5 usecs
[ 6.351777] calling alsa_pcm_init+0x0/0x75 [snd_pcm] @ 317
[ 6.351787] initcall alsa_pcm_init+0x0/0x75 [snd_pcm] returned 0 after 3 usecs
[ 6.408911] calling alsa_hwdep_init+0x0/0x1000 [snd_hwdep] @ 317
[ 6.408919] initcall alsa_hwdep_init+0x0/0x1000 [snd_hwdep] returned 0 after 4 usecs
[ 6.431689] calling init_sr+0x0/0x1000 [sr_mod] @ 329
[ 6.448000] calling hda_bus_init+0x0/0x14 [snd_hda_core] @ 317
[ 6.448014] initcall hda_bus_init+0x0/0x14 [snd_hda_core] returned 0 after 8 usecs
[ 6.457187] sr 4:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 6.457190] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 6.457331] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 6.457340] probe of 4:0:0:0 returned 1 after 25641 usecs
[ 6.457354] initcall init_sr+0x0/0x1000 [sr_mod] returned 0 after 9129 usecs
[ 6.459753] calling phy_init+0x0/0x2c1 [libphy] @ 325
[ 6.459786] initcall phy_init+0x0/0x2c1 [libphy] returned 0 after 26 usecs
[ 6.475080] calling phy_module_init+0x0/0x1000 [realtek] @ 325
[ 6.475148] initcall phy_module_init+0x0/0x1000 [realtek] returned 0 after 62 usecs
[ 6.478144] calling azx_driver_init+0x0/0xfc6 [snd_hda_intel] @ 317
[ 6.478185] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 6.478358] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops)
[ 6.478495] probe of 0000:00:1b.0 returned 1 after 337 usecs
[ 6.478514] initcall azx_driver_init+0x0/0xfc6 [snd_hda_intel] returned 0 after 356 usecs
[ 6.610213] calling ledtrig_audio_init+0x0/0x1000 [ledtrig_audio] @ 349
[ 6.610219] initcall ledtrig_audio_init+0x0/0x1000 [ledtrig_audio] returned 0 after 2 usecs
[ 6.630900] calling generic_driver_init+0x0/0x1000 [snd_hda_codec_generic] @ 349
[ 6.630925] initcall generic_driver_init+0x0/0x1000 [snd_hda_codec_generic] returned 0 after 18 usecs
[ 6.635161] calling i8k_init+0x0/0xd17 [dell_smm_hwmon] @ 327
[ 6.647483] initcall i8k_init+0x0/0xd17 [dell_smm_hwmon] returned 0 after 12028 usecs
[ 6.652317] calling realtek_driver_init+0x0/0x1000 [snd_hda_codec_realtek] @ 349
[ 6.652816] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3221: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 6.652817] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.652819] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 6.652820] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 6.652821] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 6.652822] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 6.652823] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 6.660426] probe of hdaudioC0D0 returned 1 after 8093 usecs
[ 6.660458] initcall realtek_driver_init+0x0/0x1000 [snd_hda_codec_realtek] returned 0 after 7938 usecs
[ 6.725570] calling dcdbas_init+0x0/0x1000 [dcdbas] @ 327
[ 6.725653] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 6.725664] probe of dcdbas returned 1 after 28 usecs
[ 6.725669] initcall dcdbas_init+0x0/0x1000 [dcdbas] returned 0 after 92 usecs
[ 6.848349] calling rtl8169_pci_driver_init+0x0/0x1000 [r8169] @ 325
[ 6.848382] r8169 0000:09:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 6.850191] libphy: r8169: probed
[ 6.850351] r8169 0000:09:00.0 eth0: RTL8105e, e0:db:55:a6:39:99, XID 40c, IRQ 34
[ 6.850365] probe of 0000:09:00.0 returned 1 after 2001 usecs
[ 6.850383] initcall rtl8169_pci_driver_init+0x0/0x1000 [r8169] returned 0 after 1979 usecs
[ 6.858757] calling hdmi_driver_init+0x0/0x1000 [snd_hda_codec_hdmi] @ 354
[ 6.859622] probe of hdaudioC0D3 returned 1 after 856 usecs
[ 6.859636] initcall hdmi_driver_init+0x0/0x1000 [snd_hda_codec_hdmi] returned 0 after 853 usecs
[ 6.860686] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 6.860743] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 6.860803] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 7.010298] calling serio_raw_drv_init+0x0/0x1000 [serio_raw] @ 325
[ 7.010315] initcall serio_raw_drv_init+0x0/0x1000 [serio_raw] returned 0 after 12 usecs
[ 7.067497] calling logi_djreceiver_driver_init+0x0/0x1000 [hid_logitech_dj] @ 320
[ 7.067801] probe of 0003:046D:C52F.0001 returned 0 after 14 usecs
[ 7.067949] logitech-djreceiver 0003:046D:C52F.0001: hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-3/input0
[ 7.069855] calling rfkill_init+0x0/0x120 [rfkill] @ 327
[ 7.069916] initcall rfkill_init+0x0/0x120 [rfkill] returned 0 after 55 usecs
[ 7.075989] calling atkbd_init+0x0/0xfbc [atkbd] @ 325
[ 7.076009] initcall atkbd_init+0x0/0xfbc [atkbd] returned 0 after 16 usecs
[ 7.092867] calling rtsx_usb_driver_init+0x0/0x1000 [rtsx_usb] @ 321
[ 7.095599] probe of 1-1.3:1.0 returned 1 after 2712 usecs
[ 7.095630] usbcore: registered new interface driver rtsx_usb
[ 7.095636] initcall rtsx_usb_driver_init+0x0/0x1000 [rtsx_usb] returned 0 after 2698 usecs
[ 7.098911] calling psmouse_init+0x0/0x91 [psmouse] @ 325
[ 7.098963] initcall psmouse_init+0x0/0x91 [psmouse] returned 0 after 41 usecs
[ 7.099560] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input12
[ 7.099632] probe of serio0 returned 1 after 23616 usecs
[ 7.103432] probe of serio1 returned 0 after 3794 usecs
[ 7.119254] probe of 0003:046D:C52F.0001 returned 1 after 51445 usecs
[ 7.119269] calling media_devnode_init+0x0/0x1000 [media] @ 314
[ 7.119270] media: Linux media interface: v0.10
[ 7.119293] initcall media_devnode_init+0x0/0x1000 [media] returned 0 after 17 usecs
[ 7.119667] probe of 0003:046D:C52F.0002 returned 0 after 10 usecs
[ 7.119855] logitech-djreceiver 0003:046D:C52F.0002: hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-3/input1
[ 7.140399] calling mei_hdcp_driver_init+0x0/0x1000 [mei_hdcp] @ 325
[ 7.142912] probe of mei::b638ab7e-94e2-4ea2-a552-d1c54b627f04:01 returned 1 after 2501 usecs
[ 7.142937] initcall mei_hdcp_driver_init+0x0/0x1000 [mei_hdcp] returned 0 after 2474 usecs
[ 7.154308] calling usbnet_init+0x0/0x1000 [usbnet] @ 328
[ 7.154314] initcall usbnet_init+0x0/0x1000 [usbnet] returned 0 after 1 usecs
[ 7.171486] probe of 0003:046D:C52F.0002 returned 1 after 51811 usecs
[ 7.171505] initcall logi_djreceiver_driver_init+0x0/0x1000 [hid_logitech_dj] returned 0 after 16784 usecs
[ 7.172269] logitech-djreceiver 0003:046D:C52F.0002: device of type eQUAD step 4 DJ (0x04) connected on slot 1
[ 7.172753] input: Logitech Wireless Mouse PID:4057 Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input15
[ 7.172934] input: Logitech Wireless Mouse PID:4057 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input16
[ 7.173022] hid-generic 0003:046D:4057.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4057] on usb-0000:00:14.0-3/input1:1
[ 7.173035] probe of 0003:046D:4057.0003 returned 1 after 665 usecs
[ 7.180412] calling videodev_init+0x0/0x8a [videodev] @ 314
[ 7.180414] videodev: Linux video capture interface: v2.00
[ 7.180437] initcall videodev_init+0x0/0x8a [videodev] returned 0 after 12 usecs
[ 7.181425] calling cdc_driver_init+0x0/0x1000 [cdc_ether] @ 328
[ 7.181457] usbcore: registered new interface driver cdc_ether
[ 7.181460] initcall cdc_driver_init+0x0/0x1000 [cdc_ether] returned 0 after 30 usecs
[ 7.186021] calling dell_wmi_descriptor_driver_init+0x0/0x1000 [dell_wmi_descriptor] @ 325
[ 7.189671] calling rndis_driver_init+0x0/0x1000 [rndis_host] @ 328
[ 7.190001] probe of 8D9DDCBC-A997-11DA-B012-B622A1EF5492 returned 1 after 3971 usecs
[ 7.190025] initcall dell_wmi_descriptor_driver_init+0x0/0x1000 [dell_wmi_descriptor] returned 0 after 340 usecs
[ 7.192879] rndis_host 3-1:1.0 usb0: register 'rndis_host' at usb-0000:00:14.0-1, RNDIS device, 1e:dc:5c:5b:24:a7
[ 7.192901] probe of 3-1:1.0 returned 1 after 3218 usecs
[ 7.192924] usbcore: registered new interface driver rndis_host
[ 7.192929] initcall rndis_driver_init+0x0/0x1000 [rndis_host] returned 0 after 3176 usecs
[ 7.194924] calling joydev_init+0x0/0x1000 [joydev] @ 324
[ 7.194931] initcall joydev_init+0x0/0x1000 [joydev] returned 0 after 3 usecs
[ 7.236310] calling dell_smbios_init+0x0/0xf52 [dell_smbios] @ 327
[ 7.236412] probe of dell-smbios.0 returned 1 after 18 usecs
[ 7.236451] dell-smbios A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[ 7.236465] probe of A80593CE-A997-11DA-B012-B622A1EF5492 returned 1 after 31 usecs
[ 7.236548] initcall dell_smbios_init+0x0/0xf52 [dell_smbios] returned 0 after 227 usecs
[ 7.275957] calling wmi_bmof_driver_init+0x0/0x1000 [wmi_bmof] @ 321
[ 7.276024] probe of 05901221-D566-11D1-B2F0-00A0C9062910 returned 1 after 53 usecs
[ 7.276037] initcall wmi_bmof_driver_init+0x0/0x1000 [wmi_bmof] returned 0 after 74 usecs
[ 7.279966] calling dell_init+0x0/0x903 [dell_laptop] @ 327
[ 7.280061] probe of dell-laptop returned 1 after 20 usecs
[ 7.285585] initcall dell_init+0x0/0x903 [dell_laptop] returned 0 after 5478 usecs
[ 7.291746] Adding 249852k swap on /dev/sda2. Priority:-2 extents:1 across:249852k FS
[ 7.330771] calling memstick_init+0x0/0x1000 [memstick] @ 321
[ 7.330851] initcall memstick_init+0x0/0x1000 [memstick] returned 0 after 73 usecs
[ 7.332561] calling dell_wmi_init+0x0/0xff3 [dell_wmi] @ 320
[ 7.332720] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input20
[ 7.332797] probe of 9DBB5994-A997-11DA-B012-B622A1EF5492 returned 1 after 221 usecs
[ 7.332815] initcall dell_wmi_init+0x0/0xff3 [dell_wmi] returned 0 after 243 usecs
[ 7.341486] calling uvc_init+0x0/0x1000 [uvcvideo] @ 314
[ 7.343820] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (0bda:58c2)
[ 7.344090] calling rtsx_usb_ms_driver_init+0x0/0x1000 [rtsx_usb_ms] @ 321
[ 7.344434] probe of rtsx_usb_ms.2.auto returned 1 after 324 usecs
[ 7.344452] initcall rtsx_usb_ms_driver_init+0x0/0x1000 [rtsx_usb_ms] returned 0 after 349 usecs
[ 7.354668] r8169 0000:09:00.0 enp9s0: renamed from eth0
[ 7.356636] uvcvideo 1-1.6:1.0: Entity type for entity Extension 5 was not initialized!
[ 7.356640] uvcvideo 1-1.6:1.0: Entity type for entity Extension 8 was not initialized!
[ 7.356642] uvcvideo 1-1.6:1.0: Entity type for entity Extension 2 was not initialized!
[ 7.356644] uvcvideo 1-1.6:1.0: Entity type for entity Processing 3 was not initialized!
[ 7.356646] uvcvideo 1-1.6:1.0: Entity type for entity Camera 1 was not initialized!
[ 7.356754] input: Laptop_Integrated_Webcam_HD: In as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input21
[ 7.356821] probe of 1-1.6:1.0 returned 1 after 15306 usecs
[ 7.356848] usbcore: registered new interface driver uvcvideo
[ 7.356849] USB Video Class driver (1.1.1)
[ 7.356860] initcall uvc_init+0x0/0x1000 [uvcvideo] returned 0 after 12459 usecs
[ 7.367017] rndis_host 3-1:1.0 enp0s20u1: renamed from usb0
[ 7.378037] calling hidpp_driver_init+0x0/0x1000 [hid_logitech_hidpp] @ 321
[ 7.379410] probe of 0003:046D:4057.0003 returned 0 after 15 usecs
[ 7.384528] input: Logitech B330/M330/M3 as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input22
[ 7.385089] logitech-hidpp-device 0003:046D:4057.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech B330/M330/M3] on usb-0000:00:14.0-3/input1:1
[ 7.385868] probe of 0003:046D:4057.0003 returned 1 after 6449 usecs
[ 7.385886] initcall hidpp_driver_init+0x0/0x1000 [hid_logitech_hidpp] returned 0 after 7653 usecs
[ 7.451517] psmouse serio1: synaptics: queried max coordinates: x [..5674], y [..4754]
[ 7.479016] psmouse serio1: synaptics: queried min coordinates: x [1268..], y [1098..]
[ 7.479023] psmouse serio1: synaptics: Your touchpad (PNP: DLL0591 SYN0600 SYN0002 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 7.498986] calling ecdh_init+0x0/0x20 [ecdh_generic] @ 319
[ 7.500011] initcall ecdh_init+0x0/0x20 [ecdh_generic] returned 0 after 995 usecs
[ 7.510747] calling rtsx_usb_sdmmc_driver_init+0x0/0x1000 [rtsx_usb_sdmmc] @ 327
[ 7.510846] probe of rtsx_usb_sdmmc.1.auto returned 1 after 79 usecs
[ 7.510861] initcall rtsx_usb_sdmmc_driver_init+0x0/0x1000 [rtsx_usb_sdmmc] returned 0 after 107 usecs
[ 7.533224] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x26c00/0x0, board id: 2382, fw id: 1238635
[ 7.569324] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input14
[ 7.569422] calling bt_init+0x0/0xb2 [bluetooth] @ 319
[ 7.569423] Bluetooth: Core ver 2.22
[ 7.569439] NET: Registered protocol family 31
[ 7.569440] Bluetooth: HCI device and connection manager initialized
[ 7.569443] Bluetooth: HCI socket layer initialized
[ 7.569445] Bluetooth: L2CAP socket layer initialized
[ 7.569448] Bluetooth: SCO socket layer initialized
[ 7.569465] initcall bt_init+0x0/0xb2 [bluetooth] returned 0 after 27 usecs
[ 7.571928] probe of serio1 returned 1 after 468489 usecs
[ 7.696167] calling btusb_driver_init+0x0/0x1000 [btusb] @ 319
[ 7.696370] probe of 1-1.4:1.0 returned 1 after 176 usecs
[ 7.696400] usbcore: registered new interface driver btusb
[ 7.696406] initcall btusb_driver_init+0x0/0x1000 [btusb] returned 0 after 222 usecs
[ 7.809045] Bluetooth: hci0: BCM: chip id 70
[ 7.810062] Bluetooth: hci0: BCM: features 0x06
[ 7.826051] Bluetooth: hci0: BCM43142A
[ 7.827053] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[ 7.955257] bluetooth hci0: Direct firmware load for brcm/BCM43142A0-0a5c-21d7.hcd failed with error -2
[ 7.955262] Bluetooth: hci0: BCM: Patch brcm/BCM43142A0-0a5c-21d7.hcd not found
[ 9.022975] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[ 10.006201] Bluetooth: hci0: command 0x1003 tx timeout
[ 10.008003] Bluetooth: hci0: unexpected event for opcode 0x1003
[ 11.498097] Generic PHY r8169-900:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-900:00, irq=IGNORE)
[ 11.753718] r8169 0000:09:00.0 enp9s0: Link is Down
[ 14.516107] SAME REV: no_force Returning NO_NEW old = 0x21 new = 0x21
[ 25.282712] calling bnep_init+0x0/0xba [bnep] @ 605
[ 25.282715] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.282716] Bluetooth: BNEP filters: protocol multicast
[ 25.282722] Bluetooth: BNEP socket layer initialized
[ 25.282727] initcall bnep_init+0x0/0xba [bnep] returned 0 after 8 usecs
[ 29.058252] logitech-hidpp-device 0003:046D:4057.0003: HID++ 4.5 device connected.
[ 35.380888] calling rfcomm_init+0x0/0xe4 [rfcomm] @ 853
[ 35.380982] Bluetooth: RFCOMM TTY layer initialized
[ 35.380988] Bluetooth: RFCOMM socket layer initialized
[ 35.380997] Bluetooth: RFCOMM ver 1.11
[ 35.381007] initcall rfcomm_init+0x0/0xe4 [rfcomm] returned 0 after 107 usecs
[ 38.244884] rfkill: input handler disabled
[ 49.878213] Bluetooth: hci0: command 0x1003 tx timeout
[ 49.879631] Bluetooth: hci0: unexpected event for opcode 0x1003
[ 50.044300] calling crypto_cmac_module_init+0x0/0x1000 [cmac] @ 1162
[ 50.044305] initcall crypto_cmac_module_init+0x0/0x1000 [cmac] returned 0 after 1 usecs
[ 68.063966] traps: chrome[1214] trap int3 ip:55af9db2ec65 sp:7ffc0c039390 error:0 in chrome[55af9b2ab000+6f10000]
[ 68.543705] traps: chrome[1280] trap int3 ip:55cfb94a1c65 sp:7ffecef7ed20 error:0 in chrome[55cfb6c1e000+6f10000]
[ 68.938029] traps: chrome[1293] trap int3 ip:560334c62c65 sp:7ffe80754ac0 error:0 in chrome[5603323df000+6f10000]
