How to install ffmpeg?
I follow the tips about install ffmpeg:
curl -LO https://ffmpeg.org/releases/ffmpeg-4.2.tar.bz2
tar jxf ffmpeg-4.2.tar.bz2
cd ffmpeg-4.2
./configure --prefix=/usr/local --enable-shared && make && sudo make install
sudo sh -c ‘echo /usr/local/lib >>/etc/ld.so.conf’
sudo ldconfig
But it still cannot find the library.
have no idea now.
Hi there,
the easiest way to install ffmpeg is greginator’s 3rd party repository:
Check the codec section of the readme for details:
Thank you, but I can not install mp4 support . Me too , I have not idea
This isn’t working for me. Firefox is still getting playback errors. I’ve followed…
…and have searched…
https://community.clearlinux.org/search?q=codecs%20category%3A12
I cannot seem to get Firefox working correctly. For now I’m getting by with Chrome…
As your colleague forstmannbiz wrote to you: The easiest way to do it is install ffmpeg is greginator’s 3rd party repository:
sudo swupd 3rd-party add greginator https://clear.greginator.xyz/
sudo swupd 3rd-party bundle-add ffmpeg
echo “export LD_LIBRARY_PATH=/opt/3rd-party/bundles/greginator/usr/lib64:/opt/3rd-party/bundles/greginator/usr/lib32” >> ${HOME}/.config/firefox.conf
OH! Jeeze, I need to read slower sometimes, thank you. Yeah that worked.
NB! RESOLVED
Gregor Schram (the owner) discontinued the repo after permanently moving to Fedora. Adding the repo gives the error:
Unable to determine the latest version for repository greginator
One can try the following:
