android@clr~/onedrive $ sudo swupd bundle-add sqlite
Loading required manifests...
Warning: Bundle "sqlite" is already installed, skipping it...
1 bundle was already installed
android@clr~/onedrive $ sudo swupd bundle-add devpkg-curl
Warning: Bundle "devpkg-curl" is already installed, skipping it...
android@clr~/onedrive $ make
dmd -g -ofonedrive -O -L-lcurl -L-lsqlite3 -L-ldl -J. src/config.d src/itemdb.d src/log.d src/main.d src/monitor.d src/onedrive.d src/qxor.d src/selective.d src/sqlite.d src/sync.d src/upload.d src/util.d
make: dmd: Command not found
make: *** [Makefile:29: onedrive] Error 127
rclone works with onedrive, maybe that helps you?
We don’t have the D compiler (dmd) packaged in Clear Linux. You’d have to compile that first yourself.
