I played before with kernel-native and kernel-lts2018.
Since I realise that to update I have the new and the old kernel-native I remove the kernel-lts
clr-boot-manager list-kernels
show 1 kernel but when I reboot I have 2 kernels(native and lts)
Did you remove the lts2018 kernel with swupd command?
yes , remove with
sudo swupd bundle-remove kernel-lts
Kernel-lts includes kernel-lts2018,
So please, remove kernel-lts2018 too.
Warning: Bundle “kernel-lts2018” is not installed, skipping it…
Failed to remove 1 of 1 bundles
The kernel is not showing at /usr/lib/kernel but it is showed at boot menu, Is that right?
yes,at /usr/lib/kernel I have kernel-native with orange colour
default-native
initrd-org.clearlinux.current.5.1.4-3
initrd-org.clearlinux.lts2017.4.14.121-37
initrd-org.clearlinux.lts2017.4.14.122-38
initrd-org.clearlinux.lts2017.4.14.123-39
initrd-org.clearlinux.lts2018.4.19.45-43
initrd-org.clearlinux.lts2018.4.19.48-48
initrd-org.clearlinux.mainline.5.1.0-2
initrd-org.clearlinux.native.5.1.7-777
install.d
Ok , this is an issue that we need to fix.
ok,thank you…the old kernel-native will delete when i run
sudo swupd clean
after i see that CL boot with the new kernel…that is great !
so,I tried again,add and remove the kernel-lts…
after clean,clr-boot-manager list-kernels show:
org.clearlinux.native.5.1.9-781
org.clearlinux.lts2018.4.19.50-50
and to reboot have now 3 entries-2 kernel-lts and 1 kernel-native
seems to me that clean command delete the kernel-native but not the kernel-lts
…so,remove the kernel-lts not remove the kernel-lts2018,.after remove lts2018 ,clr-boot-manager show only the kernel-native
