Hi, I want to install a custom kernel module for the USB Wifi adapter but can’t install the module with error.
Current version:
swupd info
Distribution: Clear Linux OS
Installed version: 34290
I built the module from source: GitHub - cilynx/rtl88x2bu: rtl88x2bu driver updated for current kernels.
modinfo 88x2bu
filename: /lib/modules/5.10.16-1025.native/kernel/drivers/net/88x2bu.ko
version: v5.8.7.1_35809.20191129_COEX20191120-7777
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: 788D7F4DFCA1781C74CBF0E
Unable to install module:
sudo insmod 88x2bu.ko
insmod: ERROR: could not insert module 88x2bu.ko: Key was rejected by service
Dmesg:
[300479.276452] 88x2bu: Loading of unsigned module is rejected
What can I do to install this module? Thanks.
Edit: Solution https://docs.01.org/clearlinux/latest/guides/kernel/kernel-modules.html
