mpv is “autodetecting”. In other words, it doesn’t really use compile flags, but, just detects the presence of supporting libraries to turn them on/off. That’s why enabling Lua was relatively trivial, I just added LuaJIT as a dependency (not in this git tree yet, will take 1-2 days).
Thank you @ahkok :slightly_smiling_face
I’m looking for a way to play encrypted DVDs and whether i would need to compile a local version of mpv myself. I’ve already built libdvdnav,libdvdread and libdvdcss in the usual /usr/local.
Obviously the easy way would be to get Flatpak VLC, but i wouldn’t then learn as much in the process.
Unlikely we will ever include the needed support for that, so, I would strongly suggest you try and compile it. It’s not super complicated, but getting all the OS dependencies is always tricky to get it 100% right.
