[Problem] mpv bundle "/usr/lib64/libSvtAv1Enc.so.1: CPU ISA level is lower than required"
Hello,
I am currently experiencing an issue with the mpv bundle on Clear Linux. When attempting to use it, I receive the following error message:
This error suggests that the CPU Instruction Set Architecture (ISA) level of my system is not meeting the requirements for the libSvtAv1Enc.so.1 library.
I would appreciate any assistance or suggestions on how to resolve this issue. Thank you in advance for your help.
Hello Dapal!
I just installed it here as a bundle and it works fine for me, I’m listening an mp3 file right now through mpv.
Yep, based on the error it seems that the bundle is compiled with some instructions that my CPU doesn’t support. I wonder if this could be updated to compile with some older instructions for my Intel Celeron N2808.
Should be fixed in the next version!
mpv now works perfectly fine!
