For CL 40690 I have noticed that when using GDM or logging into GNOME. The /usr/libexec/mutter-x11-frames binary keeps crashing.
Jan 20 08:05:53 clr-912e704f04584fb493b108f9f9e1d8be systemd[1]: Started systemd-coredump@332-18257-0.service.
Jan 20 08:05:53 clr-912e704f04584fb493b108f9f9e1d8be gnome-shell[18241]: ERROR: ICD associated with VkPhysicalDevice does not support GetPhysicalDeviceCalibrateableTimeDomainsKHR
Jan 20 08:05:53 clr-912e704f04584fb493b108f9f9e1d8be gnome-shell[18241]: libEGL warning: egl: failed to create dri2 screen
Jan 20 08:05:53 clr-912e704f04584fb493b108f9f9e1d8be systemd[1]: systemd-coredump@331-18216-0.service: Deactivated successfully.
Jan 20 08:05:53 clr-912e704f04584fb493b108f9f9e1d8be systemd-coredump[18217]: [🡕] Process 18201 (mutter-x11-fram) of user 1000 dumped core.
Stack trace of thread 18201:
#0 0x000055e170898f3b __pthread_kill_implementation (libc.so.6 + 0x98f3b)
#1 0x000055e170841682 __GI_raise (libc.so.6 + 0x41682)
#2 0x000055e17082649f __GI_abort (libc.so.6 + 0x2649f)
#3 0x000055e16c8ce1c3 terminator_GetPhysicalDeviceCalibrateableTimeDomainsKHR (libvulkan.so.1 + 0x2e1c3)
#4 0x000055e161fb37f2 check_have_device_time (zink_dri.so + 0xedb7f2)
#5 0x000055e161fb59ea zink_create_screen (zink_dri.so + 0xedd9ea)
#6 0x000055e161b52941 pipe_loader_sw_create_screen (zink_dri.so + 0xa7a941)
#7 0x000055e161b52829 pipe_loader_create_screen_vk (zink_dri.so + 0xa7a829)
#8 0x000055e16118ddda kopper_init_screen (zink_dri.so + 0xb5dda)
#9 0x000055e1611939d5 driCreateNewScreen2 (zink_dri.so + 0xbb9d5)
#10 0x000055e16cdcb6e6 dri2_create_screen (libEGL_mesa.so.0 + 0x236e6)
#11 0x000055e16cdd0e2e dri2_initialize_x11_swrast (libEGL_mesa.so.0 + 0x28e2e)
#12 0x000055e16cdc85b0 dri2_initialize (libEGL_mesa.so.0 + 0x205b0)
#13 0x000055e16cdb8a43 eglInitialize (libEGL_mesa.so.0 + 0x10a43)
#14 0x000055e1717f5a50 gdk_display_init_egl (libgtk-4.so.1 + 0x491a50)
#15 0x000055e1717c71db gdk_x11_display_init_gl_backend (libgtk-4.so.1 + 0x4631db)
#16 0x000055e1717f6064 gdk_display_init_gl (libgtk-4.so.1 + 0x492064)
#17 0x000055e1717c1f1b gdk_x11_display_open (libgtk-4.so.1 + 0x45df1b)
#18 0x000055e1717f0154 gdk_display_manager_open_display (libgtk-4.so.1 + 0x48c154)
#19 0x000055e1715128e7 gdk_display_open_default (libgtk-4.so.1 + 0x1ae8e7)
#20 0x000055e1715133d9 gtk_init (libgtk-4.so.1 + 0x1af3d9)
#21 0x000055e171c196f8 main (mutter-x11-frames + 0x36f8)
#22 0x000055e170827d77 __libc_start_call_main (libc.so.6 + 0x27d77)
#23 0x000055e170827e35 __libc_start_main_impl (libc.so.6 + 0x27e35)
#24 0x000055e171c19791 _start (mutter-x11-frames + 0x3791)
While doing some Google searching I came across this Fedora thread.
Although I’m not sure it’s 100% related.
FYI, I’m using NVIDIA Driver Version: 545.23.06
