( I also posted on reddit : https://www.reddit.com/r/ClearLinux/comments/pmtt7u/microsoft_surface_laptop_go_almost_509k_in_octane/ )
I was surprised that I reached 50.5k in octane v2 with my Microsoft Suface Laptop Go and surface linux kernel (chrome on xubuntu) and only 50.0-k with Clear Linux …
… I tried to install the surface linux kernel rpm but rpm could not find the kernel-install script and the install failed …
I also tried rpm2cpio to manually install the kernel but it would not be listed by “clr-boot-manager list-kernels” ( https://docs.01.org/clearlinux/latest/guides/kernel/kernel-development.html )
I am wondering if it could be relatively easy to install the Surface Linux Kernel ??
Any idea if I could get some performance improvement over regular Clear Linux kernel ?
Or maybe I could see even better performance improvement with flags optimized for my Surface Laptop Go i5 1035G1 ?
PS :
btw here is the message I get when running rpm without “–nodeps” :
root@clr-laptopgo/home/pierro78/Downloads # rpm -U kernel-surface-5.13.13-1.fc34.x86_64.rpm
warning: kernel-surface-5.13.13-1.fc34.x86_64.rpm: Header V4 RSA/SHA256 Signature, key ID ac421453: NOKEY
error: Failed dependencies:
/bin/sh is needed by kernel-surface-5.13.13-1.fc34.x86_64
/usr/bin/kernel-install is needed by kernel-surface-5.13.13-1.fc34.x86_64
coreutils is needed by kernel-surface-5.13.13-1.fc34.x86_64
dracut >= 027 is needed by kernel-surface-5.13.13-1.fc34.x86_64
linux-firmware >= 20150904-56.git6ebf5d57 is needed by kernel-surface-5.13.13-1.fc34.x86_64
systemd >= 200 is needed by kernel-surface-5.13.13-1.fc34.x86_64
systemd >= 203-2 is needed by kernel-surface-5.13.13-1.fc34.x86_64
