Online Accounts not working correctly
Hey :slight_smile:!
i started using Clear Linux today.
I tried to add my Google Account, but the system does not take over the account.
Bildschirmfoto%20vom%202019-07-24%2023-41-48
some ideas?
I had reported this issue and itโ€™s not fixed yet.
Thank you.
I do not have an Github Account :innocent:
I am getting this problem. Is this solved already?
This issue is already fixed.
It was working fine with my earlier installation. But that system broke with some upgrade. I created another disk for this. But it is not working now. Please guide me how to fix it.
Perhaps:
Solved the problem. Thanks.
Facebook account still not working.
The problem started again from last couple of updates. Canโ€™t check emails anymore added using online accounts.
I tried the above solutions again, but no difference.
Its doing nothing by clicking the buttons in online accounts.
account1
I thing it is possible with xorg and not with wayland to connect
Thanks - I ran that command (sudo glib-compile-schemas /usr/share/glib-2.0/schemas/) and it fixed gnome online accounts stalling problem that was preventing me from setting up a Google account. Iโ€™m using an Intel NUC9 Extreme.
