you can install a browser from flathub with flatpak. you can check a browsers codec support at https://html5test.com/
you can install ffmpeg with bash script from here. you can also try to install ffmpeg from source, see here
the vlc bundle is also missing codecs, and you can also install that with flatpak
This is expected and documented. See: https://docs.01.org/clearlinux/latest/FAQ/index.html#is-ffmpeg-available
Greetings,
I too wished for Firefox to support more codecs when trying Clear Linux for the first time. So much so that I too automated the installation of FFmpeg and dependencies to include vp9 support. Afterwards, Firefox scores 512 out of 555 points https://html5test.com/s/2fdc395767a6bb55.html.
https://github.com/marioroy/ffmpeg-on-clear-linux
Before with Nouveau driver (default configuration, no changes):
https://web.basemark.com/
result: 515
https://browserbench.org/MotionMark1.2/
result: 476
Flying over Japan (4K UHD)
https://www.youtube.com/watch?v=461zOyjrGPI
Hardware acceleration: 2160p 4k video playback (vp9 works)
Before with NVIDIA driver (default configuration, no changes):
result: 1289
result: 708
! Your browser can't play this video.
After with NVIDIA driver:
result: 1369
result: 970
Hardware acceleration :) 2160p 4k video playback
Added wish request to swupd, issue 1587, for repair to not break NVIDIA driver installation.
