[Problem] Segmentation Fault when trying to remove bundle with swupd
Hi, so I reinstalled Clear Linux, and saw that now bundles components seems to be removable? I was trying the new feature, but when trying to delete evolution-data after deleting evolution, I get a segmentation fault error, and I don’t know why. I tried to remove orphans with swupd, but got no luck.
Is this normal behavior? Thank you!
I’m seeing the same behavior also (after a reinstall). Not sure if something has happened or its directly related to the evolution-* packages (but now it looks like nothing can be removed).
I also did a repair and still no dice. (also re-added the evolution-basic and evolution bundles which works (the last 2 successful bundles to be removed)).
I’m guessing this is a new issue as you’re also reporting this only a day or so ago.
update: I just successfully removed gimp-basic (so it might be evolution specific?)
(@william.douglas if you want to comment)
This may be related to swupd bundle-remove --orphans causes Segmentation fault after removing os-clr-on-clr-dev · Issue #3322 · clearlinux/distribution
We did a big update to the way swupd handles bundles recently - see Clear Linux project level bundles - News and Announcements - Clear Linux OS Forum
Please enter bugs on github as you find them.
Chris
Tried other bundles and seems that it does happen with some, and it doesn’t with others. As pixelgeek suggestion, I will file a bug report.
