Thanks @Businux for the help. I watched the video and a few others. I am unable to create any environments showed in the tutorials I have watched. I keep getting an error:
conda create ==name py38
WARNING: A directory already exists at the target location ‘/usr’
but it is not a conda environment.
Continue creating environment (y/[n])? y
>>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
File "/usr/lib/python3.10/site-packages/conda/exceptions.py", line 1080, in __call__
return func(*args, **kwargs)
File "/usr/lib/python3.10/site-packages/conda/cli/main.py", line 84, in _main
exit_code = do_call(args, p)
File "/usr/lib/python3.10/site-packages/conda/cli/conda_argparse.py", line 83, in do_call
return getattr(module, func_name)(args, parser)
File "/usr/lib/python3.10/site-packages/conda/cli/main_create.py", line 41, in execute
install(args, parser, 'create')
File "/usr/lib/python3.10/site-packages/conda/cli/install.py", line 116, in install
if context.use_only_tar_bz2:
File "/usr/lib/python3.10/site-packages/conda/base/context.py", line 746, in use_only_tar_bz2
import conda_package_handling.api
ModuleNotFoundError: No module named 'conda_package_handling'
$ /usr/bin/conda create ==name py38
environment variables:
CIO_TEST=
CONDA_DEFAULT_ENV=base
CONDA_EXE=/usr/bin/conda
CONDA_PREFIX=/usr
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=/usr/bin/python
CONDA_ROOT=/usr
CONDA_SHLVL=1
CURL_CA_BUNDLE=
JAVA_INCLUDE_PATH=/usr/lib/jvm/java-1.18.0/include
LA_PATH=/usr/lib64/
MPI_PATH=/usr/lib64/
PATH=/usr/bin:/usr/bin:/usr/condabin:/usr/bin/haswell:/usr/local/bin:/usr/b
in:/opt/3rd-party/bin:/home/cmhservices/Chia/forktools:/home/cmhservic
es/Chia/forktools
PYTHONIOENCODING=utf-8:surrogateescape
REQUESTS_CA_BUNDLE=
SSL_CERT_FILE=
WINDOWPATH=2
active environment : base
active env location : /usr
shell level : 1
user config file : /home/cmhservices/.condarc
populated config files :
conda version : 4.11.0
conda-build version : not installed
python version : 3.10.6.final.0
virtual packages : __linux=5.19.1=0
__glibc=2.36=0
__unix=0=0
__archspec=1=x86_64
base environment : /usr (read only)
conda av data dir : /usr/etc/conda
conda av metadata url : None
channel URLs : main/linux-64
main/noarch
r/linux-64
r/noarch
package cache : /usr/pkgs
/home/cmhservices/.conda/pkgs
envs directories : /home/cmhservices/.conda/envs
/usr/envs
platform : linux-64
user-agent : conda/4.11.0 requests/2.28.1 CPython/3.10.6 Linux/5.19.1-1175.native clear-linux-os/36820 glibc/2.36
UID:GID : 1000:1000
netrc file : None
offline mode : False
An unexpected error has occurred. Conda has prepared the above report.
If submitted, this report will be used by core maintainers to improve
future releases of conda.
Would you like conda to send this report to the core maintainers?
