Hello,
I have Clear Linux version 36400 installed and can’t get Python 3.9 package installed as I need it for QGIS extension. How do I install Python 3.9 or configure QGIS pacakge to use Python 3.10?
Hello,
Hi datty,
As a general tip, don’t use Python from the system for development. You should take a look to install another Python via conda for this. The main advantage is that you won’t modify any system dependent package. I believe you can install Python v. 3.9 there.
https://docs.conda.io/projects/conda/en/latest/user-guide/install/index.html
