After disabling systemd-resolved (And keeping and/or enabling NetworkManager) my resolv.conf file keeps being overwrriten by a symlink to …/run/systemd/resolve/resolv.conf
My idea would be managing resolv.conf file manually.
So far I have disabled systemd-resolved by running the following commands:
sudo systemctl disable systemd-resolved
sudo systemctl mask systemd-resolved
Also tried restarting the NetworkManager service to check if that was replacing resolv.conf file, but nothing changed, I just loose it on every reboot.
Thanks in advance!
EDIT #1:
Tried creating file /etc/NetworkManager/NetworkManager.conf and appending single line dns=none , this broke my network completely with no IP assignation. After file removal and rebooting resolv.conf issue continues.
WORKAROUND:
Checking some systemd news file learned about the chattr +i command that avoid filechanges even for sudo/root privileges.
sudo -s
unlink /etc/resolv.conf
echo $'nameserver 8.8.8.8\nsearch .' > /etc/resolv.conf
chattr +i /etc/resolv.conf
