Rsnapshot on clear linux?
Just wondering if anyone has installed rsnapshot on clear linux? I can’t find any information in Software or the Forum about installing it.
bump… I have all my other requirements sorted except this one. Is it possible at present to install rsnapshot on ClearLinux?
For immediate use, you should be able to build it from source and install yourself: GitHub - rsnapshot/rsnapshot: a tool for backing up your data using rsync (if you want to get help, use https://lists.sourceforge.net/lists/listinfo/rsnapshot-discuss)
For getting it into Clear Linux as a native package, submitting a request on GitHub for a new package will be better tracked Sign in to GitHub · GitHub
