CL is statless
https://docs.01.org/clearlinux/latest/guides/clear/stateless.html
System defaults can be easily restored by simply deleting everything under /etc/
and /var
Every user gets its own home-directory.
Is it possible to have for each user separate /etc/
and /var
at login?
I have a damaged CL. I want to do a fresh install of CL and restore “/home/user”, “/etc/” and “/var” out of damaged CL into fresh CL, but for an additional user.
Is it possible to switch at login not only “/home/user” but also “/etc” and “/var” per user?
I want to restart with a fresh install of CL with two users. User one as per fresh install. User two as user in damaged CL.
Means “stateless” only resetting or also switching into other states different/varying per user?
