I need a crontab job to be run every 15min. It do not need to be cron but it’s the only thing I know. I tried to use crontab and got this message:
$ crontab -e
crontab: command not found
To install crontab use: sudo swupd bundle-add cronie
I thought it looks good, installed cronie, added cron job (crontab -e as root) to run something each */15 min. But it do not run at all. It’s same entrance from old (debian) server and it worket there, also running the command by hand it also runs.
Should I enable some daemon?
