So, when I open steam It displays this error Could not load module 'vgui2_s.so'
Terminal output:
Couldn't import apt, please install python3-apt or update steamdeps for your distribution.
steam.sh[617426]: Running Steam on clear-linux-os 35970 64-bit
steam.sh[617426]: STEAM_RUNTIME is enabled by the user
setup.sh[617495]: Steam runtime environment up-to-date!
steam.sh[617426]: Steam client's requirements are satisfied
[2022-03-26 12:32:18] Startup - updater built Mar 14 2022 19:48:46
Installing breakpad exception handler for appid(steam)/version(1647446817)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2022-03-26 12:32:19] Loading cached metrics from disk (/home/Admin/.local/share/Steam/package/steam_client_metrics.bin)
[2022-03-26 12:32:19] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2022-03-26 12:32:19] Using the following download hosts for Public, Realm steamglobal
[2022-03-26 12:32:19] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-03-26 12:32:19] Checking for update on startup
[2022-03-26 12:32:19] Checking for available updates...
[2022-03-26 12:32:19] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
[2022-03-26 12:32:19] Download skipped: /client/steam_client_ubuntu12 version 1647446817, installed version 1647446817, existing pending version 0
[2022-03-26 12:32:19] Nothing to do
[2022-03-26 12:32:19] Verifying installation...
[2022-03-26 12:32:19] Performing checksum verification of executable files
[2022-03-26 12:32:20] Verification complete
Loaded SDL version 2.0.21-7140709
src/steamUI/Main.cpp (3045) : !"Fatal Error: Could not load module 'bin/vgui2_s.dll'"
assert_20220326123220_6.dmp[617590]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220326123220_6.dmp
[2022-03-26 12:32:20] Shutdown
LD_LIBRARY_PATH=. ldd vgui2_s.so output:
||linux-gate.so.1 (0xf7f60000)|
||libdl.so.2 => /usr/lib32/libdl.so.2 (0xf7e2e000)|
||libstdc++.so.6 => /usr/lib32/libstdc++.so.6 (0xf7bdd000)|
||libpthread.so.0 => /usr/lib32/libpthread.so.0 (0xf7bd8000)|
||librt.so.1 => /usr/lib32/librt.so.1 (0xf7bd3000)|
||/usr/lib/ld-linux.so.2 (0xf7f62000)|
||libtier0_s.so => ./libtier0_s.so (0xf7b8c000)|
||libvstdlib_s.so => ./libvstdlib_s.so (0xf7b1e000)|
||libX11.so.6 => /usr/lib32/libX11.so.6 (0xf787a000)|
||libXi.so.6 => /usr/lib32/libXi.so.6 (0xf7875000)|
||libXrandr.so.2 => /usr/lib32/libXrandr.so.2 (0xf7870000)|
||libXext.so.6 => /usr/lib32/libXext.so.6 (0xf7869000)|
||libXrender.so.1 => /usr/lib32/libXrender.so.1 (0xf7864000)|
||libGL.so.1 => /opt/nvidia/lib32/libGL.so.1 (0xf77df000)|
||libfontconfig.so.1 => /usr/lib32/libfontconfig.so.1 (0xf777c000)|
||libfreetype.so.6 => /usr/lib32/libfreetype.so.6 (0xf76a3000)|
||libgtk-x11-2.0.so.0 => not found|
||libglib-2.0.so.0 => /usr/lib32/libglib-2.0.so.0 (0xf74ed000)|
||libopenal.so.1 => /usr/lib32/libopenal.so.1 (0xf7366000)|
||libXinerama.so.1 => /usr/lib32/libXinerama.so.1 (0xf7361000)|
||libSM.so.6 => /usr/lib32/libSM.so.6 (0xf735c000)|
||libICE.so.6 => /usr/lib32/libICE.so.6 (0xf7357000)|
||libXtst.so.6 => /usr/lib32/libXtst.so.6 (0xf734e000)|
||libm.so.6 => /usr/lib32/libm.so.6 (0xf7260000)|
||libc.so.6 => /usr/lib32/libc.so.6 (0xf700b000)|
||libgcc_s.so.1 => /usr/lib32/libgcc_s.so.1 (0xf6fea000)|
||libGLX.so.0 => /opt/nvidia/lib32/libGLX.so.0 (0xf6fb0000)|
||libGLdispatch.so.0 => /opt/nvidia/lib32/libGLdispatch.so.0 (0xf6efa000)|
||libexpat.so.1 => /usr/lib32/libexpat.so.1 (0xf6ec6000)|
||libuuid.so.1 => /usr/lib32/libuuid.so.1 (0xf6ebd000)|
||libbz2.so.1.0 => /usr/lib32/libbz2.so.1.0 (0xf6e9e000)|
||libpng16.so.16 => /usr/lib32/libpng16.so.16 (0xf6e4f000)|
||libz.so.1 => /usr/lib32/libz.so.1 (0xf6e27000)|
||libpcre.so.1 => /usr/lib32/libpcre.so.1 (0xf6d95000)|
I’m using steam runtime.
