Environment:
- Intel(R) Core™ i9-10940X CPU @ 3.30GHz (14 cores)
- Hyper-thread off
- 32GB Memory
- Clearlinux 42770
kernel command /etc/kernel/cmdline.d/hpe.conf, make cpu core (1-13) isolated.
intel_idle.max_cstate=0
processor.max_cstate=1
idle=poll
pcie_aspm=performance
mce=ignore_ce
ipmi_si.force_kipmi=0
nmi_watchdog=0
hpet=disabled
noht
nohz=on
nohalt
nosoftlockup
pti=off
spectre_v2=off
l1tf=off
nospec_store_bypass_disable
no_stf_barrier
mds=off
irqaffinity=0
selinux=0
audit=0
tsc=reliable
mitigations=off
intel_pstate=disable
skew_tick=1
transparent_hugepage=never
iommu=off
intel_iommu=off
rcu_nocb_poll
pcie_port_pm=off
clocksource=tsc
acpi_irq_nobalance
module.sig_unenforce
isolcpus=1-13
nohz_full=1-13
rcu_nocbs=1-13
runing sysjitter: ./sysjitter --runtime 10 200 | column -t
in kernel org.clearlinux.ltscurrent.6.6.64-1447, got expected result: isolated cpu cores has no interrupts(int_n_per_sec) during benchmark.
core_i: 0 1 2 3 4 5 6 7 8 9 10 11 12 13
threshold(ns): 200 200 200 200 200 200 200 200 200 200 200 200 200 200
cpu_mhz: 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311
runtime(ns): 10002823577 10002822834 10002822971 10002824374 10002823325 10002822947 10002822961 10002823062 10002822743 10002823198 10002823117 10002823660 10002823478 10002825002
runtime(s): 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003
int_n: 10126 0 0 0 0 0 0 0 0 0 0 0 0 4
int_n_per_sec: 1012.314 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.400
int_min(ns): 555 0 0 0 0 0 0 0 0 0 0 0 0 1237
int_median(ns): 3504 0 0 0 0 0 0 0 0 0 0 0 0 1362
int_mean(ns): 2763 0 0 0 0 0 0 0 0 0 0 0 0 1510
int_90(ns): 3759 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_99(ns): 5678 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_999(ns): 73101 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_9999(ns): 158149 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_99999(ns): 172710 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_max(ns): 172710 0 0 0 0 0 0 0 0 0 0 0 0 2201
int_total(ns): 27989402 0 0 0 0 0 0 0 0 0 0 0 0 6043
int_total(%): 0.280 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
in kernel org.clearlinux.native.6.12.4-1518, got unexpected result: isolated cpu cores has about 2 interrupts per second (int_n_per_sec) during benchmark.
cpu_mhz: 3311 3322 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311 3311
runtime(ns): 10003023405 9969901169 10003023673 10003023434 10003023686 10003024300 10003023266 10003023555 10003024161 10003023876 10003023949 10003023414 10003023461 10003025463
runtime(s): 10.003 9.970 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003 10.003
int_n: 10847 20 26 22 24 26 24 21 26 26 24 20 18 18
int_n_per_sec: 1084.372 2.006 2.599 2.199 2.399 2.599 2.399 2.099 2.599 2.599 2.399 1.999 1.799 1.799
int_min(ns): 553 984 800 829 826 736 804 811 869 826 851 846 1713 1642
int_median(ns): 3458 2042 1713 1870 1813 1813 1803 1852 1832 1835 1884 2019 2955 2942
int_mean(ns): 4773 2387 1990 2252 2047 2012 2079 2274 2120 2115 2134 2425 2558 2533
int_90(ns): 3814 3585 3241 3361 3132 3238 3279 3443 3368 3410 3630 3566 3516 3247
int_99(ns): 33648 4474 4140 4353 4138 3891 4195 4061 5646 4916 3780 4007 3883 4291
int_999(ns): 122059 4474 4140 4353 4138 3891 4195 4061 5646 4916 3780 4007 3883 4291
int_9999(ns): 157194 4474 4140 4353 4138 3891 4195 4061 5646 4916 3780 4007 3883 4291
int_99999(ns): 2758484 4474 4140 4353 4138 3891 4195 4061 5646 4916 3780 4007 3883 4291
int_max(ns): 2758484 4474 4140 4353 4138 3891 4195 4061 5646 4916 3780 4007 3883 4291
int_total(ns): 51784231 47754 51752 49557 49147 52318 49917 47775 55130 55010 51220 48517 46061 45604
int_total(%): 0.518 0.000 0.001 0.000 0.000 0.001 0.000 0.000 0.001 0.001 0.001 0.000 0.000 0.000
Anyone has idea why?
