Systemd-networkd How To Manage enable timing of 2 or more NICS
Is there a way to force the systemd-networkd to hold off turning on the static route network interface after an event or more time? I have reviewed the man page
man systemd.network. There appears to be setting called: systemd-networkd-wait-online and related
keywords is there an example that is known to delay the timing of when and interface is configured/enabled?
I have two network cards installed virtually on the VMware player.
Network interfaces ens33 and ens36, I have Clear Linux behaving as a router.
When I reboot
ens33 will go from a status of routable to degraded then I need issue the command:
I have configuration files defined in
$ ls -l /etc/systemd/network/
total 12
-rw-r–r-- 1 root root 84 Aug 8 16:34 10-dhcp.network
-rw-r–r-- 1 root root 375 Aug 8 14:59 20-static.network
sudo systemctl restart systemd-networkd. Then system works
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 ens33 ether routable configured
3 ens36 ether routable configured
I have Clear Linux version below installed on VMware player Version 15.2
NAME=“Clear Linux OS”
VERSION=1
ID=clear-linux-os
ID_LIKE=clear-linux-os
VERSION_ID=36750
PRETTY_NAME=“Clear Linux OS”
ANSI_COLOR=“1;35”
HOME_URL=“https://clearlinux.org
SUPPORT_URL=“https://clearlinux.org
BUG_REPORT_URL="mailto:dev@lists.clearlinux.org"
PRIVACY_POLICY_URL=“Intel Privacy Notice
BUILD_ID=36750
