Hey, my first question here
Is it possible to install Tailscale in CL? How?
I would email the Tailscale address listed at the bottom and get their feedback on it.
sudo curl -fsSL https://tailscale.com/install.sh | sh
Password:
Output:
Couldnât determine what kind of Linux is running.
You could try the static binaries at:
_https://pkgs.tailscale.com/stable/#static
If youâd like us to support your system better, please email support@tailscale.com
and tell us what OS youâre running.
Please include the following information we gathered from your system:
OS=other-linux
VERSION=
PACKAGETYPE=
UNAME=Linux clearlinux 6.0.1-1199.native #1 SMP Wed Oct 12 11:35:03 PDT 2022 x86_64 GNU/Linux
NAME=âClear Linux OSâ
VERSION=1
ID=clear-linux-os
ID_LIKE=clear-linux-os
VERSION_ID=37450
PRETTY_NAME=âClear Linux OSâ
ANSI_COLOR=â1;35â
HOME_URL=âhttps://clearlinux.orgâ
SUPPORT_URL=âhttps://clearlinux.orgâ
BUG_REPORT_URL="mailto:dev@lists.clearlinux.org"
PRIVACY_POLICY_URL=âIntel Privacy Noticeâ
BUILD_ID=37450
The ultimate would be if Tailscale creates a Clear bundle to add to their repo.
There is a feature request in github to add Clear Linux to the install script.
But the dev says the script probably cant be adapted due to the bundle manager. He noted that additional knowledge on swupd management would be needed.
Tailscale simply rides on top of Wireguard, which there is references on how to setup on Clear.
I used the Linux âOtherâ process for Tailscale as defined on their website.
Basically runs the binary directly or you can have it run in systemd. (they provide the config files)
No dice. Clear refused to run the tailscaler binary.
I might be missing something, but it will need some development it appears.
Can run binary but when rebooting service dont start:
systemctl status tailscaled.service
Ă tailscaled.service - Tailscale node agent
Loaded: loaded (/usr/lib/systemd/system/tailscaled.service; enabled; preset: disabled)
Active: failed (Result: resources) since Fri 2022-10-21 19:54:30 CEST; 16min ago
Docs: Docs ¡ Tailscale
okt 21 19:54:30 clearlinux systemd[1]: tailscaled.service: Scheduled restart job, restart counter is at 5.
okt 21 19:54:30 clearlinux systemd[1]: Stopped Tailscale node agent.
okt 21 19:54:30 clearlinux systemd[1]: tailscaled.service: Start request repeated too quickly.
okt 21 19:54:30 clearlinux systemd[1]: tailscaled.service: Failed with result âresourcesâ.
okt 21 19:54:30 clearlinux systemd[1]: Failed to start Tailscale node agent.
Did you install the network basic bundle and wireguard prior to running the binary?
dont need network basic or wireguard i think. Just correct path.
Can start now and have a working session but after reboot service dont start
Can network-pre.target be the problem? I dont know.
Clear Linux is very promising but lacks some support.
Vill try to solve this weekend, then back to debianâŚ
