My motherboard does not have video output. So, I think my processor’s built in graphics doesn’t work the same way as your laptop. I really don’t want it to work anyway
I also installed the 38400 server on a SATA drive for fun. Added the desktop-kde bundle. Installed the beta NVIDIA driver using @marioroy 's repo.
Now able to boot into kde with Wayland or x11. I am hoping the Clear Linux development team will add the option to install the proprietary NVIDIA driver in the distro clr-installer like Ubuntu and Arch linux do. Please!!!
Firefox 110.0.0 or 110.0.1 may have introduced a regression. It requires one to export MOZ_DRM_DEVICE
in ~/.config/firefox.conf or ~/bin/run-firefox script. Your device path may differ.
export MOZ_DRM_DEVICE=/dev/dri/renderD128
Please refer to the nvidia-vaapi-driver repo for further details. The issue is not caused by the the vaapi backend driver. Rather an anomaly in Firefox.
Let me make a new update. I stopped using GNOME because I found it too simple and without options, despite that I needed to constantly press Meta key or take the mouse pointer to the upper-left corner in order to see the main dash panel to launch new apps (there is no option in GNOME to make that panel visible on the main desktop). So, I continue using KDE, which I am using since a lot of years ago.
Now, I discovered the functional and correct way to use the NVIDIA GPU as default in a laptop with Optimus configuration and I want to share with you all.
After I install the ClearLinux OS, KDE desktop bundles and NVIDIA drivers, I create and adjust some files, then restart and the magic is done spectacularly: Wayland fully using NVIDIA GPU as primary.
[/etc/environment.d/10-sddm.conf]
__NV_PRIME_RENDER_OFFLOAD=1
__VK_LAYER_NV_optimus=NVIDIA_only
__GLX_VENDOR_LIBRARY_NAME=nvidia
[/etc/sddm.conf.d/wayland.conf]
[General]
DisplayServer=wayland
GreeterEnvironment=QT_WAYLAND_SHELL_INTEGRATION=layer-shell,QT_QPA_PLATFORM=wayland
InputMethod=
[Wayland]
CompositorCommand=kwin_wayland --no-lockscreen
With this tweaks, you will be able to execute SDDM using Wayland through “kwin_wayland” and start the “Plasma Wayland” session with Wayland using NVIDIA GPU through PRIME Screen Offload with no efforts and transparently.
Some screenshots:
XFCE / Wayland is in the works too :
There is a video of Fedora 38 running GNOME on Wayland. What is great about the video is the author shares the list of GNOME extensions used; 1m50s. For example, Dash to Dock. He mentioned having to build just one extension. The other extensions installed fine.
Someone suggested I try hyper-terminal. I was using Kitty before, but is unappealing opening new windows due to the “mutter-x11-frames” regression. That is on Xorg (1).
Today, I learned that hyper-terminal (2) can create tabs and vertical/horizontal panes, similar to qterminal. The gnome-desktop-environment + the pop-shell-extension (3) + hyper-terminal work seamlessly together without visual artifacts. One can choose to add new tabs, open new windows or create vertical/horizontal panes. To clarify, the tabs (including vertical/horizontal panes) are managed by the terminal application. Pop-shell manages new windows.
The pop-shell extension (3) would be a welcome addition to the Clear Linux desktop experience. I tried pop-shell on Nobara Linux 37 and Fedora Linux 38. Tiling in Gnome (similar to sway) is quite nice. One can toggle tiling using a keyboard shortcut.
I also tried gnome-terminal. Opening new tabs in gnome-terminal while the pop-shell extension is enabled is visually unappealing. The entire window is removed momentarily and then re-appears with one extra tab.
(1) I’m using Xorg, awaiting for Chrome (Chromium-Freeworld) to support fractional scaling on Wayland. That’s on its way and just a matter of time.
(2) Hyper-Terminal: https://hyper.is/
(3a) Package name in Fedora Linux: gnome-shell-extension-pop-shell
(3b) Pop!_OS Keyboard Shortcuts - System76 Support
The above is subjective. Use what you like.
I know you said you wanted to archive the github repo and walk away, but I want to say thanks for sticking around. I really hope the Clear Linux team is willing to support Nvidia drivers, and AMD drivers. At least for a bit until Intel drivers on Arc series graphics mature.
Driver 545.23.06 is out. Big jump from 535. Installed it using your scripts without an issue. As usual, unable to run a Wayland session with my RTX4090 and it is okay. Unable to run Wayland since Gnome 45 and CL 40xx updates.
Wayland functional after installing KDE.
Thanks so much for this. Running 545.23.06 with Wayland in GNOME. NVIDIA RTX A6000
Thanks to the author for the scripts. I have successfully installed NVIDIA drivers several times. But recently I decided to install the latest drivers and the installation ended with an error. The installer log had a message about the kernel option CONFIG_MODULE_SIG_FORCE being enabled and the need to sign modules. The error was that the openssl command was not found.
I solved the problem by generating a key pair with certtool:
cat << EOF > cert.conf
cn = nvidia-kernel-module
expiration_days = 3650
EOF
certtool --generate-privkey --rsa --bits 4096 --outfile nvidia-module-private.key
certtool --generate-self-signed --load-privkey nvidia-module-private.key --template cert.conf --outfile nvidia-module-public.key --outder
and adding arguments to install-driver:
args+=" --module-signing-secret-key=/usr/local/share/ca-certs/nvidia/nvidia-module-private.key"
args+=" --module-signing-public-key=/usr/local/share/ca-certs/nvidia/nvidia-module-public.key"
After that, the installation was successful.
p.s. substitute your own path to the keys
p.p.s. CL 43720, kernel-native, NVIDIA-Linux-x86_64-575.64.03
Updated:
On GitHub I found an option to run the installer with the parameters:
--module-signing-secret-key=/dev/null
--module-signing-public-key=/dev/null
--module-signing-script=/bin/true
Perhaps this is an easier way to install, but I haven’t tried it myself
I had the same issue with openssl not found. What I ended up doing wad downloading openssl from github, compiling, and linking to /usr/local/bin.
