I’m trying to build a module from source code with dkms. I have managed to setup the dkms but when I build it i get the following error:
Building module:
cleaning build area…
make -j12 KERNELRELEASE=5.5.2-903.native -C /lib/modules/5.5.2-903.native/build SUBDIRS=/var/lib/dkms///build modules…(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.5.2-903.native (x86_64)
Consult /var/lib/dkms/ttyPos/1.0/build/make.log for more information.
When I consult the make.log I get the following errors:
make: Entering directory ‘/usr/lib/modules/5.5.2-903.native/build’
make[2]: *** No rule to make target ‘scripts/basic/fixdep.c’, needed by ‘scripts/basic/fixdep’. Stop.
make[1]: *** [Makefile:501: scripts_basic] Error 2
make: *** [Makefile:678: include/config/auto.conf.cmd] Error 2
make: Leaving directory ‘/usr/lib/modules/5.5.2-903.native/build’
I have downloaded the required bundles (linux-dev and kernel-native-dkms) but still cannot figure out what is happening.
Can someone give me a hand on this?
Thank you.
It looks like an issue in the project’s Makefile or maybe the make command that dkms.conf is invoking needs to be tweaked.
Can you share a link to what you’re tying to install?
I cannot share the source files, they are not public, however I can share the Makefile and dkms.conf.
Also, I can give you the project structure, if it helps, which is:
- dkms.conf
- Makefile
- ttyPos.c
- ttyPos.h
- ttyTest.c
Imagine that this module gives access to a specific vendor devices in order to communicate with them (debug, etc)
Makefile
KERNEL_VER:=$(shell uname -r)
KERNEL_DIR:=/lib/modules/$(KERNEL_VER)/build
INSTALL_DIR:=/lib/modules/$(KERNEL_VER)/ttyPos
obj-m := ttyPos.o
all:
$(MAKE) modules -C $(KERNEL_DIR) SUBDIRS=$(shell pwd)
clean:
$(RM) *.o .ko .mod. ..cmd *~
$(RM) -r .tmp_versions
$(RM) *.order *.symvers
install: all
install -D -m 644 ttyPos.ko $(INSTALL_DIR)/ttyPos.ko
/sbin/depmod -a
uninstall:
modprobe -r ttyPos ; echo -n
$(RM) $(INSTALL_DIR)/ttyPos.ko
/sbin/depmod -a
dkms.conf
MAKE=“make -C ${kernel_source_dir} SUBDIRS=${dkms_tree}/${PACKAGE_NAME}/${PACKAGE_VERSION}/build modules”
CLEAN=“make -C ${kernel_source_dir} SUBDIRS=${dkms_tree}/${PACKAGE_NAME}/${PACKAGE_VERSION}/build clean”
BUILT_MODULE_NAME=ttyPos
PACKAGE_NAME=ttyPos
PACKAGE_VERSION=1.0
DEST_MODULE_LOCATION=/kernel/drivers/other
AUTOINSTALL=yes
Is this exactly what it said? Looks like maybe it’s missing PACKAGE_NAME
and PACKAGE_VERSION
in the /var/lib/dkms/.../build
path somehow.
Or are you getting this in make.log
as: unrecognized option '-mbranches-within-no-boundaries'
(see not able to compile nvidia dkms module · Issue #1725 · clearlinux/distribution · GitHub)
The above error is the exact I get. /var/lib/dkms/…/build contains the dkms.conf which includes both PACKAGE_NAME & PACKAGE_VERSION.
Also, I’m not getting
as: unrecognized option ‘-mbranches-within-no-boundaries’
anywhere in the make.log.
Can you try taking the MAKE
and CLEAN
lines out of dkms.conf
? The defaults should work fine, and I suspect the variables just aren’t being substituted properly. Also, $
is missing in a lot of your pastes.
Yeah, that fixed the error but know I get the:
I saw, the workaround is to move to lts channel or build my own kernel, is that right?
As written in the nvidia driver thread
Im affected by it too. I dont think that it is totally related to Nvidia. My guess is that some flags are passed through to dkms.
I was not able to find anything about the flag “-mbranches-within-no-boundaries”
What I have found “-mbranches-within-32B-boundaries” AFAIK this is needed to mitigate the Jump Conditional Code Issue. Benchmarks Of JCC Erratum: A New Intel CPU Bug With Performance Implications On Skylake Through Cascade Lake - Phoronix
But “-mno-branches-within-32B-boundaries” does exist …maybe it is just some typo?
edit: it does exist binutils/0004-i386-Add-mbranches-within-32B-boundaries.patch at f5fa47ed3a295ec067e27c8981c88aa8cbdc8166 · clearlinux-pkgs/binutils · GitHub
@anon93869965
After several retries I managed to build the module. Don’t know how, for real.
@CochainComplex It doesn’t seem that binutils nor -mno-branches-within-32B-boundaries was my (actual) problem, however, I got into them, but afterwards they disappeared. And If you ask me, no changes where made, just deleted dirs, copied files again and re-build them (as [https://docs.01.org/clearlinux/latest/guides/kernel/kernel-modules-dkms.html ] says).
