Would anybody know how I can use the latest stable version of Microsoft edge instead of Firefox? Keep it simple please. I’m not a programmer
there is no simple solution. edge is not in the swupd repo and never will be, considering it’s proprietary nature.
(which i am very thankful for. i have very bad PTSD when it comes to edge, back from the days when i still used windows.
however, the rpm is available for download.
Thanks. How do I install it using the rpm?
https://go.microsoft.com/fwlink?linkid=2149137
I have previously said that only the insider channels are available. That is incorrect.
Btw, edge is based on chrome, you can install chromium with flatpak.
