Hi guys I was about to send my problems regarding a touchscreen not working. But I just manage to make it work!
So:
modinfo goodix
filename: /lib/modules/5.0.18-767.native/kernel/drivers/input/touchscreen/goodix.ko
modprobe Goodix
modprobe: FATAL: Module Goodix not found in directory /lib/modules/5.0.18-767.native
Mmmm different forlder!
cp /lib/modules/5.0.18-767.native/kernel/drivers/input/touchscreen/goodix.ko /lib/modules/5.0.18-767.native
modprobe goodix
And it works!
I am just a developer, I am familiar with linux (sometimes I think I am good at it xD) but this seems strange, doesnt it? Why was the .ko file not located where the command was trying to find it. And also why did it miss the cap. in the first letter?
Regards
modprobe failed because it’s case sensitive. modinfo also failed and just points you to the basedir where it starts searching. This works:
$ modinfo goodix
filename: /lib/modules/5.0.15-754.native/kernel/drivers/input/touchscreen/goodix.ko
license: GPL v2
description: Goodix touchscreen driver
author: Bastien Nocera <hadess@hadess.net>
author: Benjamin Tissoires <benjamin.tissoires@gmail.com>
alias: i2c:GDIX1001:00
alias: acpi*:GDIX1002:*
alias: acpi*:GDIX1001:*
depends:
retpoline: Y
intree: Y
vermagic: 5.0.15-754.native SMP mod_unload
sig_id: PKCS#7
signer:
sig_key:
sig_hashalgo: unknown
signature:
$ sudo modprobe goodix
$ lsmod | grep goodix
goodix 24576 0
This doesn’t:
$ modinfo Goodix
modinfo: ERROR: Module Goodix not found.
$ sudo modprobe Goodix
modprobe: FATAL: Module Goodix not found in directory /lib/modules/5.0.15-754.native
Pablo_Muniz_Gadea:
modprobe Goodix
Yeap as @btwarden said it is a typo
