Hi I am trying to install old game using wine but without success.
Has anyone experienced the same problem ?
wine cs16full_v6.exe
wine: created the configuration directory ‘/home/dognyanov/.wine’
INTEL-MESA: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
0048:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
0048:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
0048:err:ole:apartment_get_local_server_stream Failed: 0x80004002
0050:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
0050:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
0050:err:ole:apartment_get_local_server_stream Failed: 0x80004002
0050:err:ole:start_rpcss Failed to open RpcSs service
0040:err:setupapi:SetupDefaultQueueCallbackW copy error 1812 L"@wineusb.sys,-1" -> L"C:\windows\inf\wineusb.inf"
0064:fixme:file:NtLockFile I/O completion on lock not implemented yet
0064:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0064:err:mscoree:LoadLibraryShim error reading registry key for installroot
006c:fixme:file:NtLockFile I/O completion on lock not implemented yet
006c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
006c:err:mscoree:LoadLibraryShim error reading registry key for installroot
0074:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
0074:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
006c:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
0064:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0084:fixme:file:NtLockFile I/O completion on lock not implemented yet
0084:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0084:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
008c:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x33c306d, context 0x7ab69a0, init_notify 0, handle 0x85cfa70): stub
0040:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0104:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
0104:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
0104:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0104:err:winediag:nodrv_CreateWindow The explorer process failed to start.
010c:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
010c:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
010c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
010c:err:winediag:nodrv_CreateWindow The explorer process failed to start.
Could not find Wine Gecko. HTML rendering will be disabled.
0114:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
0114:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
wine: configuration in L"/home/dognyanov/.wine" has been updated.
0024:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
0024:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
0148:err:module:open_builtin_file failed to load .so lib “/usr/lib32/wine/winex11.drv.so”
0148:err:user:load_desktop_driver failed to load L"C:\windows\system32\winex11.drv"
014c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
014c:err:winediag:nodrv_CreateWindow The explorer process failed to start.
if I run winecfg , the windows appears but there are errors in the console:
