Hi there,
this my first post here. I switched from Windows 10 a few days ago because of trouble with windows updates here to clear linux os.
I really like that OS and still would like to use it as main and only os on my pc. So right now I don’t have a parallel windows installation. I just wiped it away with all that update troubles.
Right now I’m looking for how to get my Garmin Devices working. I would like to use Garmin Basecamp and Garmin Express further.
So I’ve tried to install Garmin Basecampt first by that install guide: WineHQ - Basecamp 4.2.5
Moreover the following swupd bundles were installed before already:
wine
wget
samba
At the first step of the install guide I will get a lot of error and fixme messages. I’m not sure if there is anyone I should take care about? (I canceled installation of mono - its not installed in .cache/wine/)
$ WINEPREFIX=~/.garmin WINEARCH='win32' wine wineboot -u
wine: created the configuration directory '/home/marcel/.garmin'
0012:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0012:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0012:err:ole:get_local_server_stream Failed: 80004002
0014:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0014:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0014:err:ole:get_local_server_stream Failed: 80004002
0019:fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
0019:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0019:err:mscoree:LoadLibraryShim error reading registry key for installroot
0019:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0010:fixme:dwmapi:DwmIsCompositionEnabled 6D95DD14
001b:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x6a0df537, context 0x3ad570, init_notify 0, handle 0x165fcd8): stub
0010:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
wine: configuration in L"/home/marcel/.garmin" has been updated.
003e:fixme:dwmapi:DwmIsCompositionEnabled 6D95DD14
0042:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x6a0df537, context 0x3ad570, init_notify 0, handle 0x154fcd8): stub
003e:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
When I go on with the second step of the install guide I will just get three lines feedback. And thats all. There is nothing that ask me for user interaction. So I think it won’t be installed correctly:
$ env WINEPREFIX=~/.garmin winetricks dotnet45 corefonts
Using winetricks 20191224-next - sha256sum: ad7e49675d0a0a1c375e28c43b5c923165fb1950f423d1d8ddbfb48248c99c6d with wine-5.2 and WINEARCH=win32
Executing w_do_call dotnet45
Executing load_dotnet45
So I think there is any problem or not solved dependency with the first step.
When I will go on with the last and third step it will abort with a PopUp in Windows Style with the Message that dotNet is not installed.
I hope anyone could help me how to install dotnet correctly in my case
