I miss background transparency in Gnome Terminal. It is useful and having difficulty adjusting to a Terminal without it.
$ sudo swupd bundle-add c-basic qt-basic qt-basic-dev
$ cd ~/Downloads
$ curl -LO https://github.com/lxqt/lxqt-build-tools/releases/download/0.8.0/lxqt-build-tools-0.8.0.tar.xz
$ curl -LO https://github.com/lxqt/qtermwidget/releases/download/0.16.1/qtermwidget-0.16.1.tar.xz
$ curl -LO https://github.com/lxqt/qterminal/releases/download/0.16.1/qterminal-0.16.1.tar.xz
for p in lxqt-build-tools-0.8.0 qtermwidget-0.16.1 qterminal-0.16.1; do
tar xf $p.tar.xz
cd $p && mkdir build && cd build
CMAKE_INSTALL_PREFIX=/usr/local cmake ..
make -j 4
sudo make install
cd ../..
done
Tuning the font DPI is possible for QT applications. This looks fine on my display.
$ sudo mkdir -p /etc/profile.d
$ sudo echo 'export QT_FONT_DPI=128' >/etc/profile.d/qt-fix.sh
Then log out of the desktop environment and log back in. Voila! One will have QTerminal and able to adjust background transparency via File Menu > Appearance > Terminal transparency > (for example) 11%.
Clear Linux has become more fun
Since my last post, I made an improvement to the QTerminal experience. New windows and tabs execute bash with -login. The current working directory preference is honored as well. Therefore, provided a solution for an old issue option to start shell as login shell. New windows, new tabs, including new horizontal and vertical spaces behave consistently with regards to bash -login.
That said, my updated notes for building Qterminal on Clear Linux.
$ cd ~/Downloads
tar xf $p.tar.xz
done
# Appy change to qterminal.desktop.in qterminal directory
# https://github.com/lxqt/qterminal/issues/103#issuecomment-803516167
# Appy changes to MainWindow::newTerminalWindow in mainwindow.cpp
# https://github.com/lxqt/qterminal/issues/103#issuecomment-803686925
cmake -G Ninja \
-DCMAKE_POSITION_INDEPENDENT_CODE=ON \
-DCMAKE_INSTALL_PREFIX=/usr/local \
-DCMAKE_INSTALL_LIBDIR=lib \
-DBUILD_SHARED_LIBS=ON \
-DPULL_TRANSLATIONS=NO \
-DCMAKE_BUILD_TYPE=Release ..
ninja
sudo ninja install
cd ../..
done
What about scrolling performance and does it matter? Not really, but was something I measured.
$ ls -R /usr >/dev/null # ignore first run
GNOME Terminal: ls -R /usr # 2.370 seconds
QTerminal: ls -R /usr # 1.982 seconds
starting every shell as log-in shell is the default behaviour on macOS…
