This could be High CPU 0 usage again.
top shows basically nothing. I logged out and back in, still at 100% on CPU 0. iotop shows no activity.
find / -type f -name core -exec ls -l {} ; shows no core files.
What should I do to track this down?
Last time, it took a reboot. There is no swupd running that ps can find.
Hmm…so what process causes the high CPU usage, what do htop say? Have you checked after stopping rngd? Is the spike on CPU0 only shown for a short period after launching htop (if so, i guess its normal) or does it remain (if so, you should be able to identify the process)?
I ran only top, not htop. I did stop rngd, but no noticeable change occurred. After logging out and back in, whatever it was, was still running.
Since top did not show a busy process, the load average was 0.41, and the color was red, I assume it was something in the kernel?
One screenshot shows 1 running process, top, and another shows 2 running processes, and the other was pool-gnome-shel. But something is wrong in the kernel, since the process tree is not showing anyone busy, and the cpu is not charged to a process. It has to be down in the kernel. I am not a kernel guy, although, perhaps it is time to start! It took rebooting for the problem to go away.
I thought this was interesting, but it is not from the problem system:
dmesg | grep \-22
[ 1.688890] nouveau 0000:01:00.0: DRM: failed to create kernel channel, -22
So there isn’t really a visible process that drains the CPU? The following command should show the three processes with the most CPU usage, maybe this help to identify the problematic process?
It happened again. I saw nothing new in htop. Small load average of 0.44, nothing garnering more than 2 percent of a CPU,
Today, I put the laptop to sleep (not hibernation - Clear Linux does not do that). I think it may have happened when I closed the last tab on FireFox and there were no more FireFox tasks or processes. Something to play with.
Since nothing turns up on top/htop, it has to be something run amuck in the kernel.
