Hello, I just installed Clear Linux on my machine and the only way I could get the OS to boot was to use the nomodeset flag in the kernel boot options but that way Vulkan doesn’t work .Is there any way I can make the GPU work with Vulkan?
Amd based gpu should just work fine ootb, try updating clear. Also you might have to wait for LLVM 11 in clear (we are at 10). You can try building your own kernel too.
