and then I end up with a blank screen, no cursor, no reaction to any keyboard combination (Alt+F2, Ctrl+Alt+F3, Ctrl+Alt+F5,), and the monitor switching on and off indefinitely.
Ctrl+Alt+Del alone does not do anything but if I first press Ctrl+Alt+F3 and then Ctrl+Alt+Canc the system reboots as expected.
Not sure which one of the following two errors is the incriminating one:
ACPI BIOS Error (bug): Could not resolve symbol ... AE_NOT_FOUND
nvidiafb: cannot request PCI regions
Adding acpi_osi=!, or noapic acpi=off, or systemd.unit=multi-user.target to kernel parameters during boot did not change anything.
Adding module_blacklist=nouveau I could log in from a terminal.
modprobe.blacklist=nvidiafb gets rid the nvidiafb error but does not solve the problem.
In the BIOS: both secure boot and fast boot are disabled. I could not find a AHCI/IDE mode in BIOS to set on or off: closest thing was a XHCI Hand-off which enabled or disabled didn’t make any difference.
Can anyone suggest anything else I can try to be able to boot into Clear Linux GUI?
Thanks, I suspected that, had other kinds of problems in the past on other computers with Nvidia cards with other Linux distributions. I decided for sure my next graphic card will not be an Nvidia one.
I have given another try with the kernel parameters pci=noacpi nouveau.modeset=0 with no luck, ended up with this screen:
