Hi people,
I m wondering if the Compatibility test results are declaring my workstation as “Game Over” ?
…or if there is still some possible work arround for me to run Clear linux some day on this Brix…
(havent downloaded it yet)
Currently dual booting on W10 + Linux Mint :
Tool Test results :
:~/Tele/intel$ ./clear-linux-check-config.sh host
Checking if host is capable of running Clear Linux* OS
SUCCESS: 64-bit CPU (lm)
SUCCESS: Supplemental Streaming SIMD Extensions 3 (ssse3)
SUCCESS: Streaming SIMD Extensions v4.1 (sse4_1)
SUCCESS: Streaming SIMD Extensions v4.2 (sse4_2)
SUCCESS: Advanced Encryption Standard instruction set (aes)
SUCCESS: Carry-less Multiplication extensions (pclmulqdq)
FAIL: EFI firmware
:~/Tele/intel$ ./clear-linux-check-config.sh container
Checking if host is capable of running Clear Linux* OS in a container
SUCCESS: Virtualisation support (vmx)
SUCCESS: Kernel module kvm
SUCCESS: Kernel module kvm_intel
FAIL: Nested KVM support
Workstation details :
System: Host: Brix6100 Kernel: 4.15.0-65-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Machine: Type: Laptop Mobo: GIGABYTE model: MKLP3AP-00 v: 1.x serial:
UEFI [Legacy]: American Megatrends v: F4 date: 12/08/2015
CPU: Topology: Dual Core model: Intel Core i3-6100U bits: 64 type: MT MCP arch: Skylake
rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18432
Speed: 500 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Gigabyte driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1916
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: llvmpipe (LLVM 8.0 256 bits) v: 3.3 Mesa 19.0.8 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k4.15.0-65-generic
Network: Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: 3.2.6-k port: f040
bus ID: 00:1f.6 chip ID: 8086:1570
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac:
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
chip ID: 8086:3165
IF: wlp1s0 state: down mac:
Drives: Local Storage: total: 1.36 TiB used: 712.25 GiB (51.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO M.2 500GB size: 465.76 GiB
speed: 6.0 Gb/s serial:
ID-2: /dev/sdb type: USB vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
serial:
Partition: ID-1: / size: 191.39 GiB used: 115.08 GiB (60.1%) fs: ext4 dev: /dev/sda5
Thanks for any possible work arround… ![]()
