I have been attempting to build a Docker container of Rustdesk, only that I have been hitting some snags on the way. Building the container from a Rustdesk image ends with an error, and I am not sure what I may be doing wrong:
Compiling hyper-rustls v0.23.2
Compiling url v2.3.1
Compiling gdkwayland-sys v0.16.0
error: failed to run custom build command for `scrap v0.5.0 (/home/user/rustdesk/libs/scrap)`
Caused by:
process didn't exit successfully: `/home/user/rustdesk/target/debug/build/scrap-937aa0005a54bce6/build-script-build` (exit status: 101)
--- stdout
cargo:rerun-if-env-changed=NO_PKG_CONFIG_libyuv
cargo:info=x64-linux
cargo:rustc-link-lib=static=yuv
cargo:rustc-link-search=/vcpkg/installed/x64-linux/lib
cargo:include=/vcpkg/installed/x64-linux/include
cargo:rerun-if-env-changed=NO_PKG_CONFIG_libvpx
cargo:rustc-link-lib=static=vpx
rerun-if-changed=/home/user/rustdesk/libs/scrap/src/bindings/vpx_ffi.h
rerun-if-changed=/vcpkg/installed/x64-linux/include
cargo:rerun-if-env-changed=NO_PKG_CONFIG_aom
cargo:rustc-link-lib=static=aom
rerun-if-changed=/home/user/rustdesk/libs/scrap/src/bindings/aom_ffi.h
--- stderr
/home/user/rustdesk/libs/scrap/src/bindings/aom_ffi.h:1:10: fatal error: 'aom/aom.h' file not found
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: ClangDiagnostic("/home/user/rustdesk/libs/scrap/src/bindings/aom_ffi.h:1:10: fatal error: 'aom/aom.h' file not found\n")', libs/scrap/build.rs:163:18
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
warning: build failed, waiting for other jobs to finish...
Anyone have any ideas as to what may be going wrong?
P.S. The commands to build the container are posted here.
