Can i open .exe files in clearlinux? System requirements?
In other linux distributions, this is not possible without wine. is it possible now? For example, can I open a portable .exe file and .dll files without installation?
My other question is system requirements. The computer I have is Intel pentium dual core 2.00 GHz. It has 1 GB RAM and 150 GB HDD. What performance should I expect?
No unless I’m greatly mistaken, CL as other Linux distros will require wine.
As for performance with your setup , the real question is does it meet the minimum requirements to run CL ?
https://docs.01.org/clearlinux/latest/reference/system-requirements.html
sudo swupd bundle-add wine - Windows executables may or may not work. Many are not wine compatible. Check https://winehq.org for information about which applications work and which ones do not.
Without wine? if its not possible, i will download windows
No Linux OS can do this without wine, period.
Can open APK files? (Pubg mobile vs)
You can open APK files in file-roller. Just give it a try. the unzip command also opens them.
If you mean “open” in term of run/execute, then no, not without an emulator.
